Neuer Flipper "Dirty Dishes" / New "Dirty Dishes" pinball table
DirkW
Moderator
Re: Neuer Flipper "Dirty Dishes" / New "Dirty Dishes" pinball table
Beitrag von DirkW » 29 Nov 2021, 14:05
Very cool rubem,
you built it well, my compliment. :D
Since I built one myself years ago, I know how much time you put in there.
My fischertechnik Pinball "Pirates of the Caribbian"
https://www.youtube.com/watch?v=tP-TJu1L9cA
Best regards,
rubem
Beitrag von rubem » 29 Nov 2021, 14:36
DirkW hat geschrieben:
29 Nov 2021, 14:05
Very cool rubem,
Best regards,
Hello Dirk,
Thank you very much from your kind remarks. No introduction needed, I'm already a fan of your models :D Pirates of the Caribbean was perhaps the greatest inspiration for my much more modest and smaller project. I referred to it again and again. For the ball return mechanism, for example, I tried an approach similar to yours (a brilliant solution) but I had to give up on it because it added even more extra width to the right, I already had extended the width to accommodate the plunger.
Cheers,
Rubem
uffi
Beitrag von uffi » 29 Nov 2021, 17:45
Thanks for sharing your great model with all those interesting details, Rubem!
I have a question with regard to the solenoids:
- which dc resistance do they have, is it below 10 Ohms?
Are they of the type "Tau-0530T" from aliexpress?
Thanks, uffi
rubem
Beitrag von rubem » 29 Nov 2021, 18:23
Hello uffi,
The model I used is called JF-0530B, rated at 6 V. I posted more details about it here, just when I gave up on pneumatics for this project. At the time I measured the coil resistance, it's around 5.5 Ω. juh included a link to this solenoid on eBay above ↑.
I hope this helps!
Rubem
uffi
Beitrag von uffi » 29 Nov 2021, 19:20
Thanks for the fast reply, Rubem.
I have now ordered similar types on aliexpress:
TAU-0530T 12V 1,8A i.e. ca. 6,67 Ohms
https://de.aliexpress.com/item/32731717 ... 4c4dlrozJj
I will also try to build a pinball similar to yours. Thanks again, uffi
rubem
Beitrag von rubem » 30 Nov 2021, 18:28
Hello Uffi,
uffi hat geschrieben:
29 Nov 2021, 19:20
That's wonderful! I'll be glad to share some of my project files with you if you want me to, including the part layers (as shown here) and the Arduino code (partially still under development, though).
The TAU-0530T is probably the same solenoid from another manufacturer. Since it is rated at 12 V, though, I suspect you'll have to drive them with voltages higher than my 19.5 V and/or for more than 50 ms, otherwise they will not be able to shoot the ball fast enough. Please share your results here.
Greetings,
Rubem
uffi
Beitrag von uffi » 02 Dez 2021, 11:29
Hello Rubem,
thanks for your advice. I will use a power supply rated 16.5 Volts and 4.5 Amperes. I plan to extend the initial pulse to 100ms in a first step. With both solenoids activated at the same time they will consume ca. 4A leaving still some remaining current for the rest of the circuits and avoid a large voltage drop on the supply.
Have you measured the supply voltage drop when activating both of your solenoids at the same time?
If I had selected the 6V version of TAU-0530T with an ohmic resistance of 2.5 Ohms drawing 16.5 V/2.5 Ohms = 6 Amperes each, I think the power supply would not be able to hold its voltage at 16 Volts.
And I will use the VNH2SP30 high power low-ohmic MOSFET motor driver (< 30 milli Ohms) to have lowest possible voltage drop on the driver. I suppose your L298 driver will have a voltage drop of >2 Volts with >2 Amperes flowing through the bipolar transistors.
I will share my results once I am ready.
Kind regards, uffi
rubem
Beitrag von rubem » 03 Dez 2021, 18:46
Hi uffi,
Your calculations make sense, although the coil resistance of the JF-0530B is not so low, my multimeter shows 5.5 Ω. I actually didn't measure the voltage drop, but I suppose my power supply can handle short peaks of higher current anyway because the solenoids remain powerful even when both are activated at the same time. The first power supply I tested clearly could not handle the current, it switched off for a short while when I pressed both buttons.
I look forward to seeing your results.
Cheers,
Rubem
atzensepp
Beitrag von atzensepp » 11 Dez 2021, 13:55
Hello rubem,
first when I saw this I thought: Wow, is this a new set from fischertechnik? Where can I buy it?
Congratulations!
Florian (aka atzensepp)
rubem
Beitrag von rubem » 12 Dez 2021, 19:37
Hi Florian,
atzensepp hat geschrieben:
11 Dez 2021, 13:55
Congratulations!
Hahahaha :D Who knows, perhaps ft will release a similar kit one day. The controller alone must have around 30 I/O pins, though, so I doubt it ;) Thanks for your comment!
Regards,
Rubem
rubem
Beitrag von rubem » 14 Jun 2022, 00:56
Hi everyone,
I've finally finished and posted the video for my pinball table, I hope you enjoy it!
https://youtu.be/8AOQLhKPIg0
Best regards to all,
Rubem
----------------------- Google Translate ------------------------
Hallo allerseits,
Endlich habe ich das Video für meinen Flippertisch fertiggestellt und gepostet, ich hoffe es gefällt euch!
Beste Grüße an alle,
Rubem
DirkW
Moderator
Beitrag von DirkW » 14 Jun 2022, 07:14
Hello Rubem
I like your pinball very much.
Especially the clean processing and the digital display. Very professional. :D
Best regards
TimeLord
Beitrag von TimeLord » 14 Jun 2022, 18:17
Hallo Rubem,
ein fantastischer Flipperautomat und ein tolles Video.
Vielen Dank fürs zeigen :!:
Gruß, Klaus
juh
Beitrag von juh » 14 Jun 2022, 21:21
Great stuff, Rubem! Apart from the mechanical and electrical design, I particularly liked how you realized the dirty dishes motive. If only it could do the real dishes!
Jan
rubem
Beitrag von rubem » 15 Jun 2022, 20:50
Thank you @DirkW, @TimeLord and @juh for your praise!!!
Cheers, Rubem
:D
Danke @DirkW, @TimeLord und @juh für euer Lob!!!
Gruß, Rubem
Arnoud-Whizzbizz
Beitrag von Arnoud-Whizzbizz » 15 Jun 2022, 23:00
Great Rubem!
Beautiful tiny pinball machine with many original technical inventions! Optimal synergy of fischertechnik and your own inventions and ideas!
uffi
Beitrag von uffi » 04 Jan 2023, 19:21
here is my rebuilt pinball with many ideas copied from yours:
- theme changed to "Peanuts"
- modified ball elevator
- gambling sounds
https://youtu.be/9YrCwb3ZSy8
Cheers, uffi
