TXT Training Factory - Offline + Monitoring
JonasJ
Beitrag von JonasJ » 30 Okt 2020, 03:24
I purchased the TXT Training Factory (https://github.com/fischertechnik/txt_training_factory).
I have basic C++ knowledge, but never worked with TXT before.
If there is an internetconnection and a cloudconnection the factory works fine.
But if I want to run it offline, the programs of the TXT controllers stop themselfes unregualry.
How can I run the factory offline?
My second question is: What is the best way to debug the factory-programs on the TXTs.
In the source-code there is a lot of logging and monitoring: spdlog, std::cout , mqtt-message....
Unfortunately I can only see some mqtt-messages on my node-red server if the factory is running, so I have no idea
what happened if a TXT stopped working correctly.
How can I monitor the TXT controllers on runtime?
Thank you for your help!
Re: TXT Training Factory - Offline + Monitoring
Beitrag von vleeuwen » 30 Okt 2020, 12:39
You will find the answer in the diagram:
diagram
You need to find a solution to get the external functionality inside your local network.
You don't need the MQTT bridge.
But a laptop with a local version of the fischertechnik Cloud Dashboard.
If you don't have a good basic experiences and skills with C/C++ programming for the TXT, then it could be advisable to start with the basics in:
https://github.com/fischertechnik/txt_demo_c_download
(here you find also information about how to setup a development environment and how to use it.)
and maybe
https://github.com/fischertechnik/txt_demo_ROBOPro_SLI
kvqw044
Beitrag von kvqw044 » 19 Jan 2021, 21:46
I have the same issue, the TxtGatewayPLC program on the TXT keeps crashing/stopping.
Did you ever find a way to debug/find why it is happening?
There is a file /opt/knobloch/Data/TxtFactoryMain.log but nothing ever seems to written to it.
