Example RoboPro documentation generator (FootballRobot)
Beitrag von vleeuwen » 04 Okt 2019, 23:56
I created a program (POC=proof of concept) which is giving me a small overview of a RoboPro .rpp programma.
Here by the result of parsing the complex footballrobot.rpp, which is part of the TXT-discovery set. It contains 37 subroutines.
The result gives an overview of the subroutines, including the comment and the relation of the subroutines (here only max. depth=2).
Not show: it can also produce a overview of for example: used variable including the starting value, const values, list including the initial values.
The program can be see as documentation generator.
Overview of subroutines
1 subroutine= Main program
********documentation********
Enter a description for your function here.
---> Is using the next subroutines:
, (0)Triangulation, (1)TriM2, (2)UpdateY, (2)UpdateX, (1)TriM1, (2)UpdateY, (2)UpdateX, (2)UpdateA, (1)TriLR, (2)UpdateY, (2)UpdateX, (2)UpdateA, (1)BarCode15
, (0)Test, (1)TakeBall, (2)MotOn, (2)MotOff, (1)MoveHome, (2)TurnTo, (2)MoveTo, (1)KickGoal, (2)MoveFwd, (2)KickBall, (2)ForwardTo, (2)atanXY, (1)InitPos, (2)TurnL, (2)Triangulation, (1)FindBall, (2)TurnR, (2)TurnL
, (0)Odometry, (1)NormAngle
, (0)InitPos, (1)TurnL, (2)MotOn, (2)MotOff, (1)Triangulation, (2)TriM2, (2)TriM1, (2)TriLR, (2)BarCode15
, (0)Collision, (1)TurnR, (2)MotOn, (2)MotOff, (1)TurnL, (2)MotOn, (2)MotOff, (1)Soccer, (2)TakeBall, (2)MoveHome, (2)KickGoal, (2)KickBack, (2)FindBall, (1)Rot, (1)Random, (1)PntColl, (2)MotOff, (2)KickBall, (1)MoveFwd, (2)MotOn, (2)MotOff, (1)MoveBckw, (2)MotOn, (2)MotOff
, (0)Adjust, (1)TurnTo, (2)TurnR, (2)TurnL, (2)NormAngle, (1)TurnR, (2)MotOn, (2)MotOff, (1)TurnL, (2)MotOn, (2)MotOff, (1)Triangulation, (2)TriM2, (2)TriM1, (2)TriLR, (2)BarCode15, (1)MoveTo, (2)TurnTo, (2)MoveFwd, (2)atanXY, (1)MoveFwd, (2)MotOn, (2)MotOff, (1)MoveBckw, (2)MotOn, (2)MotOff, (1)InitPos, (2)TurnL, (2)Triangulation, (1)ForwardR, (2)MotOn, (2)MotOff, (1)ForwardL, (2)MotOn, (2)MotOff
2 subroutine= Adjust
, (0)TurnTo, (1)TurnR, (2)MotOn, (2)MotOff, (1)TurnL, (2)MotOn, (2)MotOff, (1)NormAngle
, (0)TurnR, (1)MotOn, (1)MotOff, (2)Triangulation
, (0)TurnL, (1)MotOn, (1)MotOff, (2)Triangulation
, (0)MoveTo, (1)TurnTo, (2)TurnR, (2)TurnL, (2)NormAngle, (1)MoveFwd, (2)MotOn, (2)MotOff, (1)atanXY
, (0)MoveFwd, (1)MotOn, (1)MotOff, (2)Triangulation
, (0)MoveBckw, (1)MotOn, (1)MotOff, (2)Triangulation
, (0)ForwardR, (1)MotOn, (1)MotOff, (2)Triangulation
, (0)ForwardL, (1)MotOn, (1)MotOff, (2)Triangulation
3 subroutine= Test
, (0)TakeBall, (1)MotOn, (1)MotOff, (2)Triangulation
, (0)MoveHome, (1)TurnTo, (2)TurnR, (2)TurnL, (2)NormAngle, (1)MoveTo, (2)TurnTo, (2)MoveFwd, (2)atanXY
, (0)KickGoal, (1)MoveFwd, (2)MotOn, (2)MotOff, (1)KickBall, (2)KickBack, (1)ForwardTo, (2)NormAngle, (2)ForwardR, (2)ForwardL, (1)atanXY
, (0)FindBall, (1)TurnR, (2)MotOn, (2)MotOff, (1)TurnL, (2)MotOn, (2)MotOff
4 subroutine= Soccer
, (0)KickBack
5 subroutine= Collision
, (0)Soccer, (1)TakeBall, (2)MotOn, (2)MotOff, (1)MoveHome, (2)TurnTo, (2)MoveTo, (1)KickGoal, (2)MoveFwd, (2)KickBall, (2)ForwardTo, (2)atanXY, (1)KickBack, (1)FindBall, (2)TurnR, (2)TurnL
, (0)Rot
, (0)Random
, (0)PntColl, (1)MotOff, (2)Triangulation, (1)KickBall, (2)KickBack
6 subroutine= BarCode15
Detects a barcode with 3 black and 2 white stripes
One of the black or white stripes is 2 as thick as the other 4 stripes.
The total width of the bar code is thus 4+2 units.
The result codes ar as follows:
1 : black bar closest to the begin of the line detector is thick
2 : middle black bar is thick
3 : black bar closest to the end of the line detector is thick
4 : white bar closest to the begin of the line detector is thick
5 : white bar closest to the end of the line detector is thick
Note: The line detector should be adjusted to detect more than 3 lines in case there is a possibility that garbage is seen towards the end of the line.
7 subroutine= Triangulation
Calculate for each of the 3 line detectors a total barcode width and a code.
The wall code assignment is as follows:
1: thick black bar low = right side wall (looking towards the goal)
2: thick black bar middle = back wall
3: thick black bar high = left side wall (looking towards the goal)
4: thick white bar low = goal
5: thick white bar high = walls left and right of goal
-1: no code detected
In case the left and the right code are detected and equal (point to the same wall), TriangulateLR is called.
In case the middle line and one other line are detected and equal  (point to the same wall), TriangulateM and TriangulateM2 is called.
Corrections:
[2019-09-25]
In the original Qr and Qm swap places
, (0)TriM2, (1)UpdateY, (1)UpdateX
, (0)TriM1, (1)UpdateY, (1)UpdateX, (1)UpdateA, (2)NormAngle
, (0)TriLR, (1)UpdateY, (1)UpdateX, (1)UpdateA, (2)NormAngle
, (0)BarCode15
8 subroutine= TriLR
Calculate the absolute angle from the sizes of two different barcodes.
This function is used if the outer left and outer right barcode have the same code (ar on the same border).
In this case the absolute angle and one of X and Y can be computed.
alpha/2 = atan 17/67 = 14.2373 deg is the angle between the middle and the left or teh middle and the right line detector.
This has been determined by scene measurement.
, (0)UpdateY
, (0)UpdateX
, (0)UpdateA, (1)NormAngle
9 subroutine= TriM1
This function is used if one of the outer and the middle barcode have the same code (are on the same border).
The other coordinate can be computed by TriangulateM2 when the other outer barcode points to a different border.
alpha/2 = atan 17/67 = 14.2373 deg is the angle between the middle and the left or the middle and the right line detector.
, (0)UpdateY
, (0)UpdateX
10 subroutine= TriM2
Calculate an additional coordinate in case the left and right line detector see a different border
, (0)UpdateY
, (0)UpdateX
11 subroutine= UpdateA
Store every result for login.
, (0)NormAngle
12 subroutine= UpdateX
13 subroutine= UpdateY
14 subroutine= TurnL
A turning test of the robot model results in 1310 steps for 4 turns.
This are 1310/1440 = 0.9097 steps per degree.
This value is for the new encoder motor
, (0)MotOn
, (0)MotOff, (1)Triangulation, (2)TriM2, (2)TriM1, (2)TriLR, (2)BarCode15
15 subroutine= TurnR
, (0)MotOn
16 subroutine= Odometry
This subprogram looks for changing motor counter values.
The difference in counter values is turned into a rotation.
The sum of the counter values is turned into a straight movement.
Angle and movement are integrated to compute the current absolute angle and X/Y position.
For better precision, the X/Y position update is done with half of the angle.
The values calculated this way are corrected by camera measurements (subprogram triangulation).
, (0)NormAngle
17 subroutine= MotOn
18 subroutine= MotOff
19 subroutine= InitPos
20 subroutine= MoveTo
, (0)atanXY
21 subroutine= atanXY
22 subroutine= TurnTo
, (0)NormAngle
23 subroutine= MoveFwd
The number of impulses per whell turn is 150
Wheel diameter = 59.5.mm
A 500 step straight drive tests result in a distance of 613mm.
This resuls in 0.81566 steps/mm
The theoretical result with a measured wheel diameter of 59.5 is 150 / (59.5mm*pi) = 0.80246/mm.
The measured distance results in a wheel diameter of 613mm/ (500/150) / pi = 58.5mm
, (0)MotOn
24 subroutine= NormAngle
25 subroutine= FindBall
26 subroutine= KickBack
27 subroutine= TakeBall
, (0)MotOn
28 subroutine= ForwardL
A turning test of the robot model results in 390.75 steps per turn.
This are 390.75/360 = 1.0854 steps per degree
, (0)MotOn
29 subroutine= ForwardR
, (0)MotOn
30 subroutine= ForwardTo
, (0)NormAngle
31 subroutine= KickGoal
, (0)KickBall, (1)KickBack
, (0)ForwardTo, (1)NormAngle, (1)ForwardR, (2)MotOn, (2)MotOff, (1)ForwardL, (2)MotOn, (2)MotOff
, (0)atanXY
32 subroutine= MoveBckw
, (0)MotOn
33 subroutine= MoveHome
34 subroutine= PntColl
35 subroutine= Rot
36 subroutine= Random
DE: Erzeugt Zufallszahlen im Bereich -32768 bis 32767
EN: Generates random number in the range -32768 to 32767
Der Algorithmus ist in D.E.Knuth, "The Art Of Computer Programming", Abschnitt 3.2.2 beschrieben.
Der Algorithmus berechnet die folgende Folge:
Z(n) = ( Z(n-24) + Z(n-55) ) mod m
wobei m gerade und Z(0)..Z(54) beliebieg ganze Zahlen sind, von denen mindestens eine nicht gerade ist.
Als m wird die Maschinenauflösung ( 65536 in ROBOPro ) verwendet, so dass die Modulo-Operation entfällt.
Die 55 Anfangswerte stammen aus der Tabelle der RAND Corporation von 1947 (Start 0, Offset -32768, Werte >32767 wurden nicht verwendet).
37 subroutine= KickBall
, (0)KickBack
olagino
Re: Example RoboPro documentation generator (FootballRobot)
Beitrag von olagino » 05 Okt 2019, 10:31
Hi vleeuwen,
I've tried myself to write some kind of a parser/interpreter for RoboPro but discontinued the project because of the limits of my free time. Although that projects documentation isn't the best, I think it could be interesting for you to test around with it. If I remember correctly, the interpreter could follow some simple example programs (and execute it via e.g. ftrobopy) but I gave up at multi-state subroutines and variable-operations.
Like i said, it might be worth a look, although I never got to finish that project properly.
https://github.com/olagino/roproparser (the main parser) and https://github.com/olagino/ropropreter (an experimental "App" for the TXT-Controller running the community-firmware)
Kind regards
olagino
Beitrag von vleeuwen » 05 Okt 2019, 12:40
Hi olagino,
Thanks,
I will take a look into it.
I will publish my C# code later, I need to add a user interface to the POC (proof of concept).
However my objectif differs a little bit from yours.
My objectif is to generated documentation which gives me information about a complex RoboPro program.
To have a overview of subroutines, variables, constants, list, presentation elements without entering and searching in al the subroutines.
In the futur I will change from .txt to .html and ad also links between the subroutines and in that subroutine used global variables.
It looks like that your objectif is more generating executable Python code.
For that you need to follow the workflow(s) in a subroutine and aso analyze the dataflow, which has been used for the synchronisation of the processes.
In fact I do the same as you, I analyze the .rpp XML file
