Robo Connect Box
Robo Connect Box
Hello FT fans,
I used my Robo Connect Box with first The Universal Interface and,second, The Intelligent interface ( serial ) , with RoboPro.
In both situations, it is impossible to vary the speed of the motors ( 0 t0 8 ) , on all M1....M4.
I would like to know if this is normal behavior with the Robo Connect Box.
Ich habe meine Robo Connect Box mit ersten die Universal-Schnittstelle und zweitens die intelligente-Schnittstelle (seriell), mit RoboPro.
In beiden Situationen ist es unmöglich, die Geschwindigkeit der Motoren zu variieren (0 t0 8), an der alle M1...M4.
Ich würde gerne wissen, ob das normale Verhalten mit der Robo Connect Box.
Grub
Marspau
Grub
Marspau
Re: Robo Connect Box
As far as I know these interfaces had no variable speeds, just on/off.
@Ad2,
Thank you for the answer, but the Robo Connect Box is suppose to make these two old interfaces behave like a Robo interface , using RoboPro SW.
So we shouid be able to control the speed of the motors.
Danke für die Antwort, aber der Robo Connect Box ist wohl um zu machen diese beiden alten Schnittstellen verhält sich wie eine Robo-Schnittstelle, mit RoboPro SW.
Also wir Shouid werden in der Lage, die Geschwindigkeit der Motoren steuern.
Grub
Marspau
Grub
Marspau
Hello Marspau,
with or without box, the behaviour as described is OK.
The Robo Interface has been the first interface being able to control the power (speed) of M1 - M4 (O1 - O8) in 8 steps.
The Robo Connect Box can't alter or overrule any hardware (or firmware) limitations of the connected interfaces.
Greatings, Stefan
Greatings, Stefan
- schnaggels
But the Robo Connect Box firmware could emulate the Robo Pro speed settings by a kind of software PWM
Not sure how fast the Universal or Intelligent interface could process these updates and if this would make sense then...
I still wait for the support of extension modules by the Robo Connect Box.
If the code would be open source other people would maybe jump on it...
But the extension modules already have USB...
- schnaggels
Did you mean the Robo IF Extensions? Yes they have but this was about the old Universal and Serial interfacesAd2 hat geschrieben:But the extension modules already have USB...
The ROBO Connect Box firmware would need to support these extensions, currently this is only done for the main interface and I afraid this will also not change as they are busy with many other mire important projects... I will follow the Arduino example mentioned in the fourum to get them connected for larger ft factory installation in the future (hopefully if I find the time
