Raspberry PI
Re: Raspberry PI
Stimmt eigentlich, den TX müsste man doch über USB an den Raspberry Pi anschließen können. Aber auf dem Raspberry Pi läuft nur Linux (oder Windows jedenfalls nicht) was bedeutet, dass man da RoboPro nicht aufspielen kann, oder? Schade, ansonsten könnte man diese App verwenden: http://forum.ftcommunity.de/viewtopic.p ... it=justins
If it is possible to install robo pro on the raspberry pi (but I think it isn't, cause on the raspberry pi Windows don't run, only Linux) it should be possible to connect the TX-controller via USB with the r-pi. And than to control with an iPhone/iPod with this app: http://forum.ftcommunity.de/viewtopic.p ... it=justins
Lg, Fischli
Lg, Fischli
Re: Raspberry PI
No you probably cannot run RoboPro (unless you have a suitable emulator), but you can still communicate with the TX when you have a virtual comport. With a simple terminal emulator you should already be able to send console commands to the TX. The next step would be X1, several people are working on X1 hosts and devices.
Re: Raspberry PI
I'ld vote for installing Linux on the TX.
ROBO Interface with Linux: http://defiant.homedns.org/~erik/ft/libft/
Re: Raspberry PI
Linux? Is that wishful thinking or do you have some ideas on how to do that?
I'm not so much interested in linux because it is probably even heavier than 4netos, but I would really like to see the hardware layer.
Re: Raspberry PI
I don't have a TX, but if you can update the firmware, then you can put Linux on it. Finding a jtag and uart will surely help of course.
Linux alreadys runs on the AT91SAM9260, so the basic task should just be to configure the devicetree (HW specific stuff like RAM) and I/Os.
Of course some experience with Linux/ARM is required..
Re: Raspberry PI
Jtag is there! http://askrprojects.net/fischertechnik/robotx.html. But which peripherals are used for what and how, that's the question.
Re: Raspberry PI
Not relevant anymore
Zuletzt geändert von vleeuwen am 01 Jul 2013, 00:01, insgesamt 1-mal geändert.
Re: Raspberry PI
die Ansteuerung des Robo-Interface klappt wunderbar mit dem Raspberry Pi, ich erhalte aber regelmäßig die Fehlermeldung
FtThread: Error reading from the Interface. Got -110 of 21 bytes
Hat das jemand hier auch? Die Firmware meines Robo-Interface ist möglicherweise zu alt, ich habe aber zur Zeit kein Windows um sie zu aktualisieren. Oder geht das auch über Linux?
Außerdem muß ich die Programme, die libroboint verwenden unter root starten. Kann man das umgehen?
MfG
MfG
Re: Raspberry PI
Liegt vermutlich am kaputten USB-Host des R-Pi. Wenn sonst alles funktioniert kann die Meldung ignoriert werden, es geht dann nur jedesmal ein Datenpaket verloren.thomasm hat geschrieben: FtThread: Error reading from the Interface. Got -110 of 21 bytes
Welchen Kernel verwendest du?
Verwendest du die udev-Regel?thomasm hat geschrieben: Außerdem muß ich die Programme, die libroboint verwenden unter root starten. Kann man das umgehen?
Re: Raspberry PI
Ich habe gerade die Firmware-Bezeichnung des Robo Interface ausgelesen. Sie lautet: "1.75.00.04". Das scheint dann wohl doch die aktuelle Version zu sein.
Re: Raspberry PI
Die udev-Regel hatte ich verwendet. Aber ich hatte den Satz "you need know to replug your device" übersehen. Wenn man das macht, geht es auch ohne sudo.
Übrigens muß in der Java-Klasse FTLibrary "roboint" als Name der Native-Library verwendet werden. Dann funktionieren auch die Java-Programme.
MfG
MfG
Re: Raspberry PI
Ach ja, die Kernel-Version:
uname -a liefert:
Linux raspberrypi 3.6.11+ #474 PREEMPT Thu Jun 13 17:14:42 BST 2013 armv6l GNU/Linux
uname -a liefert:
Re: Raspberry PI
..mir war bis eben nicht klar, daß es einen Java-wrapper gibt.
Aber schön, wenn es funktioniert.
Re: Raspberry PI
Ist denn der Java-Code nicht von Dir???
Auf jeden Fall habe ich jetzt die firmware des r-pi aktualisiert und der besagte Fehler tritt jetzt erstmal nicht mehr auf.
Jetzt fällt mir aber die Zeile
Note - Unable to set realtime priority: Operation not permitted
auf. Was hat es denn damit auf sich?
Re: Raspberry PI
Laut Versionsverwaltung kam der java-code von mir, mit fixes von zeuz. Ist aber ein paar Jahre her, daß der angefasst wurde...
Der Kommunikations-Thread der libroboint versucht sich eine Echtzeit-Priorität im Scheduler zu geben, was normalerweise nur root darf.
Kann für andere User in /etc/security/limits.conf erlaubt werden, muss aber nicht unbedingt sein.
Re: Raspberry PI
Danke. Jetzt hab ich alles zusammen und kann jetzt endlich wieder - dank r-pi - nach langer Zeit mein robo interface wieder in Betrieb nehmen und mit Java programmieren.
Jetzt brauche ich nur noch ein Lösung, wie ich aus der Original-Fischertechnik-Stromversorgung die 5V für den r-pi abzweigen kann und den r-pi in ein Fischertechnik-Gehäuse stecke, damit alles wie aus einem Guss aussieht.
Re: Raspberry PI
Beim Selbstbau kann z.B. ein LM2576 verwendet werden.
Re: Raspberry PI
Hier noch der Vollständigkeit halber:
1) das RF-Data-Link läuft bei mir nicht rund am r-pi. Ich erhalte oft die Fehlermeldung
FtThread: Error reading from the Interface. Got 0 of 42 bytes
2) die Robo-I/O-Extension macht jedoch keine Probleme.
Re: Raspberry PI
Wie oft kommt die Fehlermeldung denn?
Re: Raspberry PI
Hier die Fehlerbeschreibung:
Ich starte das mitgelieferte Java-Testprogramm, das den Motor 1 laufen läßt, bis der Taster 1 gedrückt wird. Der Motor läuft, aber nach ein paar Sekunden kommen die Fehlermeldungen. Meist sind es dann gehäuft gleich 10 hintereinander. Wenn das passiert stottert auch der Motor. Dann ist für ein paar Sekunden wieder Ruhe, bis sie erneut kommen. Mal einzeln mal gehäuft.
MfG
MfG
