Error with RoboInterface after programming RAM
hvn
Re: Error with RoboInterface after programming RAM
Beitrag von hvn » 02 Okt 2014, 17:42
Trying:
ftuploader -u 0 -U interpreterV1.01.rom -N BasicInterpreter -t FLASH1
Found program for Flash 1
Overwriting Destination: Using Flash 1
Upload Error: Target mismatch
Error uploading Program: Return value for 0xC0, 0x20 is 0xef
Sorry: upload failed
Please restart Device!
and
I do restart each time...
Defiant
Beitrag von Defiant » 02 Okt 2014, 19:27
-What firmware version of the robo interface is this?
-Is the interface directly connected or via datalink?
-In what mode is your interface?
E Hoffer
hvn
Beitrag von hvn » 02 Okt 2014, 19:37
- RoboInterface has firmware version 1.75.00.04
- It is directly connected via USB
- It is in default scan-mode, which works for uploading the .hex program to RAM.
Defiant
Beitrag von Defiant » 02 Okt 2014, 19:42
hmm same firmware as on my interface. Can you upload the interpreterV1.01.rom you are using?
E Hoffer
hvn
Beitrag von hvn » 02 Okt 2014, 19:48
I can send you per email as well. What do you prefer ?
Defiant
Beitrag von Defiant » 02 Okt 2014, 19:49
email will do
E Hoffer
Defiant
Beitrag von Defiant » 02 Okt 2014, 20:00
Bad news, I have tested the version you send me, and had no problems uploading it to an interface with the same firmware. I'm out of ideas :(
E Hoffer
hvn
Beitrag von hvn » 02 Okt 2014, 20:09
Hm..what is the exact command+syntax you used ?
Defiant
Beitrag von Defiant » 02 Okt 2014, 20:26
ftuploader -U interpreterV1.01.rom -N BasicInterpreter
ftuploader -U edgetest.hex
ftuploader -s RAM
E Hoffer
hvn
Beitrag von hvn » 02 Okt 2014, 21:42
Tried another RoboInterface with this result:
Error sending control msg 0xC0 0xF0
Warning: Program in Unknown Memory running!
2 different interfaces, different errors.
ftuploader -V:
ftuploader version: 0.5.2
libroboint version: 0.05.02
Would this matter ?
Defiant
Beitrag von Defiant » 02 Okt 2014, 21:46
hvn hat geschrieben: Error sending control msg 0xC0 0xF0
Your other interface has a running programm you need to stop first with
ftuploader -k
E Hoffer
hvn
Beitrag von hvn » 02 Okt 2014, 22:01
It seemed so but it can't since I never uploaded a program on that one before this attempt.
ftuploader -k
Stopping program failed
huub@Phinda:~/Downloads/RoboInt_Basic_Compiler/compiler$ ftuploader -n
Flash #1: <No Program stored>
Flash #2:
Ram: <No Program stored>
Getting out of ideas...
hvn
Beitrag von hvn » 03 Okt 2014, 16:58
What I keep wondering about is why an upload of a .hex file to RAM does work, but an upload of the interpreter (or anything) to flash doesn't work. How can I test if the flash is ok ?
hvn
Beitrag von hvn » 04 Okt 2014, 15:50
Next step in diagnose: booting Win2000 for test with RoboPro (latest). Loading Gripper program, upload to flash1 successful. Then back to Linux, ftuploader -n :
Flash #1: G
Flash #2: <No Program stored>
ftuploader -d flash1
Deleting program: success
ftuploader -n
So apparently, flash1 is just fine but won't be loaded from Linux (Xubuntu 14.04) ?
Defiant
Beitrag von Defiant » 04 Okt 2014, 17:24
Strange, what about flash2?
E Hoffer
hvn
Beitrag von hvn » 04 Okt 2014, 21:46
Using RoboPro download to flash2 is successful and runs. Then on Linux:
ftuploader -n
Flash #2: G
ftuploader -d flash2
ftuploader -n
ftuploader -U interpreterV1.01.rom -N BasicInterpreter -t flash2
Overwriting Destination: Using Flash 2
So flash2 is fine too. What Linux distribution/version do you use ?
Defiant
Beitrag von Defiant » 05 Okt 2014, 09:36
I don't think that this a Distribution issue. Its probably an incompatibility in the firmware.
E Hoffer
hvn
Beitrag von hvn » 05 Okt 2014, 12:14
With this as my firmware:
Firmware: 1.75.00.04
Serial: 0.04.03.88
RF frequency: 0
RF call sign: 0
of which you say you have the same version, then how can you successfully upload to flash using ftupload (again: upload to RAM is no problem for me) ?
ftuploader -V
Defiant
Beitrag von Defiant » 06 Okt 2014, 07:37
I really don't know, might be a HW or firmware change without updating the version. Uploading to ram or flash doesn't change much in my software. It executes the very same lines of code.
E Hoffer
hvn
Beitrag von hvn » 07 Okt 2014, 09:55
Could you check on the real s/n of your RoboInterface ? The oldest s/n on which I tried is 21.04, the newest s/n is 4.03.88.
