6v charger for #31494 motor
Marspau
Beitrag von Marspau » 21 Nov 2015, 21:34
Hello FT fans,
I would like to know if there is still a charger for item # 31494 motor.
A charger with a jack, in order to recharge the 4 batteries without having to remove them from the motor enclosure.
Ich würde gerne wissen, ob es noch ein Ladegerät für Artikel # 31494 Motor.
Ein Ladegerät mit einem Wagenheber, um die 4 Batterien, ohne sie aus dem Motorgehäuse zu entfernen aufzuladen.
Grub
Marspau
schnaggels
Re: 6v charger for #31494 motor
Beitrag von schnaggels » 24 Nov 2015, 17:13
Hi Marspau,
any rechargeable battery charger with a fitting plug should work.
Main issue could be to find one able to charge at least 4 cells, most I found start with 5 cells minimum.
As far as I know there was never a dedicated product from fischertechnik for this battery box.
Kind regards,
Marspau
Beitrag von Marspau » 24 Nov 2015, 17:52
Hello Schnaggels,
Thank You for the answer. I will try to find a suitable charger.
Best Regards
Marspau
