CFW: neues Python-Modul für GUIs: TouchAuxiliary.py
Beitrag von PHabermehl » 04 Feb 2017, 00:12
Hallo Python-TXT-Programmierer,
ich habe aus der App TXTShow ein Python-Modul ausgegliedert, das sicherlich auch für Andere interessant ist. Es bietet verschiedene Input-Requester, die aus Python-Scripten aufgerufen werden können.
Zu finden ist es auf GitHub in der cfw: board/fischertechnik/TXT/rootfs/opt/ftc/TouchAuxiliary.py
Und das ist darin zu finden: (Kopie des beigefügten .readme):
TouchAuxiliary is a python sub-module of the TouchStyle.py User interface module.
It provides a set of high-level user interface functionalities to easily add interactive GUIs to TXT python programs/apps.
Important: the on-screen keyboard needs some icons which are located at ../auxicons/
They must be present for the keyboard to work.
Contents:
class TouchAuxMultibutton(TouchDialog):
Opens up a window containing a list of items and returns the item selected by the user
******** function call **********
msg = TouchAuxMultibutton(title:str, parent:class)
... some of the methods to configure
(succes:bool, result:str) = msg.exec_()
with title:str Title of the input window
******** methods *************
msg.setText(text:str) Optional text above the button list
msg.setButtons(items:str[]) Array of str, contains the button text ["Button one","Button two",...]
Empty intermediate cells will be interpreted as a separator bar
msg.leftAlignButtons() Align the button Text to the left instead of center
msg.setTextSize(size:int) Sets the font size for the message text (1..4, 1 is smallest, default is 3)
msg.setBtnTextSize(size:int) Sets the font size for the button text (1..4, 1 is smallest, default is 3)
******** Return values **********
success:bool True for user confirmed selection, False for user aborted selection
result:str selected item in case of success==True or None in case of success=False
class TouchAuxFTCamPhotoRequester(TouchDialog):
opens up a requester window to make a photo snapshot
*********** function call ******************
req = TouchAuxFTCamPhotoRequester(self, title:str, width:int, height:int, button:str, parent=None)
img:QPixmap = req.exec_()
title:str title of the requester window
width:int width setpoint for the image
height:int height setpoint for the image
button:str text for the "photo" button
parent parent class, optional, defaults to "none"
class TouchAuxListRequester(TouchDialog):
(succes:bool, result:str) = TouchAuxListRequester(title:str, items:str[], inititem:str, button:str, parent:class)
******** parameters *************
items:str[] Array of string contains the list of items to be displayed
inititem:str Initially selected item, will also be returned in case of cancellation
button:str Text label for the confirm button, only considered for TouchStyle_version<1.3, otherwise confirm and cancel buttons will be part of the window title
parent:class Parent class
result:str selected item in case of success==True or inititem in case of success==False
class TouchAuxRequestInteger(TouchDialog):
Opens up a window to get a integer number input
(succes:bool, result:int) = TouchAuxListRequester(title:str, message:str, initvalue:int, maxval:int, minval:int, button:str, parent:class)
message:str text message to be displayed
initvalue:int Init value for the input dial
maxval:int Upper limit for the input number
minval:int Lower limit for the inout number
success True for user confirmed selection, False for user aborted selection
result Input value in case of success==True or initvalue in case of success==False
class TouchAuxRequestText(TouchDialog):
Opens up a Text input requester window
(success:bool, result:str) = TouchAuxRequestText(title:str, message:str, inittext:str, button:str, parent:class=None)
title:str Title of the message window
message:str Optional message to be shown
inittext:str Initial text for the input line
button:str text for the confirm button, only considered for TouchStyle_version<1.3
class TouchAuxMessageBox(TouchDialog):
""" Versatile MessageBox for TouchUI
msg = TouchMessageBox(title, parent)
(success, text) = msg.exec_()
********* Methods: *********
msg.addConfirm() (only for TouchStyle_version>=1.3) confirm button at the left of the title
msg.setCancelButton() (only for TouchStyle_version>=1.3) changes style of the close icon to cancel icon
msg.addPixmap(QPixmap) adds a QPixmap to be shown on top of the message text
msg.setPixmapBelow() places the pixmap below the text (inbetween text and buttons), defalt is above the text
msg.setText(text) sets message text, default ist empty string
msg.setPosButton(pos_button_text) sets text for positive button, default is None (no button)
msg.setNegButton(neg_button_text) sets text for negative button, default is None (no button)
msg.setTextSize(size) set 4- big 3 - normal (default); 2 - smaller; 1 - smallest
msg.setBtnTextSize(size)
msg.alignTop() aligns message text to top of the window
msg.alignCenter() centers text in window (default)
msg.alignBottom() aligns message text to bottom of the window
msg.buttonsVertical(bool=True) arrange buttons on top of each other (True, default) or side-by-side (False)
msg.buttonsHorizontal(bool=True) see above...
Return values:
success == True if one of the buttons or the confirm button was used
success == False if MessageBox was closed by its close icon (top right)
text == None if MessageBox was closed by its close icon
text == pos_button_text | neg_button_text depending on which button was clicked
class TouchAuxPicButton(QAbstractButton):
Provides an image button for PyQT Layouts
button = TouchAuxPicButton(pixmap:QPixmap, parent:class=None)
