TX-C and Java according to FAQ?
Gesperrt
Janosch Kuffner
Re: TX-C and Java according to FAQ?
Beitrag von Janosch Kuffner » 18 Feb 2011, 19:52
Hello,
thank you for calling attention to this FAQ entry.
Unfortunately this information is not correct. We will change the FAQ as soon as possible.
The library for the PC programming of the ROBO TX Controller needs a Microsoft Windows operating system. The saples which are included in the software package have been created by using Microsoft tools like Microsoft Visual C++ or Microsoft Visual Studio.
Furthermor we expect that various problems will occur if you use the PC Programming package to create a Java programm for the ROBO TX Controller. Thus we don't recommend to use this software package for the creation of Java programms for the ROBO TX Controller.
Kind regards
Janosch Kuffner
fischertechnik-Team
Beitrag von vleeuwen » 18 Feb 2011, 20:07
In addition to Janosch.
Java knows a JNI (Java Native Interface) to close the gap between the Java virtual machine and the onderlaying real machine.
But this is time consuming. In fact Java is not created for this kind of interfacing.
At the otherhand, .NET perform as preparation on the program execution a compilation of the assembly code (CLI) to the underlaying machinecode. The code is addapting to the actual hardware situation.
This makes .NET powerful and faster as Java for hardware interfacing.
Zuletzt geändert von vleeuwen am 19 Feb 2011, 17:51, insgesamt 1-mal geändert.
Defiant
Beitrag von Defiant » 20 Feb 2011, 11:08
E Hoffer
heiko
Beitrag von heiko » 20 Feb 2011, 19:38
ಠ_ಠ
Dirk Haizmann ft
Beitrag von Dirk Haizmann ft » 08 Mär 2011, 09:04
.. an another question answered.
ft
Gesperrt
