Robotics TXT - Date Fields Mismatch
Year returns day, Month returns year and Day returns month on RoboPro 4.2.3.
Re: Robotics TXT - Date Fields Mismatch
There is an additional glitch for February 29th, 2016.
EDIT Day displays seconds. February 29th is unknown. 29 is changed for 1!
Zuletzt geändert von Rei Vilo am 29 Feb 2016, 16:34, insgesamt 1-mal geändert.
Dear Rei Vilo,
this is a strange bug. Thanks for reporting it. Hopefully, this will be fixed in a future ROBOPro update.
Best regards,
Markus
Best regards,
Markus
Dear Rei Vilo,
maybe if fixes your "seconds instead of days" problem if you use different variable names for hours, minutes and seconds.
I guess seconds part of your program overwrites day variable content.
Anyway you will get months instead of days again.
Regards,
Robert
Regards,
Robert
Dear Robert:
Thank you for the suggestion.
Unfortunately, variables with different names give the same result.
Dear Rei Vilo,
yes, it does not fix the day/month/year problem as well as the added leap year problem, but the reported error in your 2nd post (seconds instead of days).
Kind reagrds,
Robert
Kind reagrds,
Robert
I tried DayOfWeek, and it provides the day of the month.
So I guess Day provides the day of the week!
I have the same problem so i cant run my simple clock. https://www.dropbox.com/s/thy176zgpgx1uwq/uhr.rpp?dl=0. In the middle it says ERROR. And my TXT says its the 29th of March.
Raphael
Raphael
Dear Rei Vilo, dear Raphael,
it seems that there are a lot of bugs concerning the date fields. We will fix this, thanks for the investigations.
Best regards,
Markus
Best regards,
Markus
Hi Markus,
i think that these bugs are there since version 4.2.3 because in v 4.1.8 and 4.2.1 (i´m not sure about the number. Mr Kaup has sent this beta to me) my clock has been working fine.
Raphael
Raphael
Dear Raphael,
thanks for this info!
best regards,
Markus
best regards,
Markus
What I don't know is whether the problem comes from the translation into English only or also exists on the German version.
Dear Rei Vilo,
unfortunately, this problem appears in all languages.
Best regards
Markus
Best regards
Markus
