Robotics TXT - Infra-Red Remote Control
Rei Vilo
Beitrag von Rei Vilo » 29 Feb 2016, 15:19
When using the IR remote with the Robotics TXT, and even with a new 9 V battery, the signal from the infra-red remote control isn’t continuous.
A program as basic as the previous one fails to run the motor continuously.
Pushing the joystick up to the top or down to the bottom and maintaining it on that position results with the motor being stopped.
ski7777
Administrator
Re: Robotics TXT - Infra-Red Remote Control
Beitrag von ski7777 » 29 Feb 2016, 20:34
My simple infrared program to control a driving car doesnt make problems. Here is a Link to my Super infrared test: https://www.dropbox.com/s/8m7t6g7v6i96g ... l.rpp?dl=0 In the last version i have removed the extra only positive and only negative variables, but i think these are handled by the software.
Raphael
Markus Burkhardt
Beitrag von Markus Burkhardt » 01 Mär 2016, 16:02
Dear Rei Vilo,
meanwhile I have tested this issue and in my case, the signal of the infrared remote-control is continous. I am afraid that your remote controller or your TXT controller is broken and needs to be fixed. Please send the devices with a short error report to the following address:
fischertechnik GmbH
Klaus-Fischer-Straße 1
72178 Waldachtal
DEUTSCHLAND
Best regards,
Markus
Rei Vilo
Beitrag von Rei Vilo » 01 Mär 2016, 18:07
Markus:
Thank you for your message.
I'm going first to test the program by ski7777 and see how it works.
Then I'll consider returning the items.
Markus Burkhardt
Beitrag von Markus Burkhardt » 02 Mär 2016, 08:41
Dear Rei Vilo,
just to be clear: on my TXT, your program for the infrared controller works well. I am pretty sure that there is a problem with your infrared controller or your TXT.
Best regards
Markus
Rei Vilo
Beitrag von Rei Vilo » 02 Mär 2016, 10:20
Markus:
Thanks! I'm sending the devices today.
Markus Burkhardt
Beitrag von Markus Burkhardt » 14 Mär 2016, 18:07
Dear Rei Vilo,
I hope that you have received the new TXT controller in the meanwhile and that this error doesn't appear anymore.
Best regards,
Markus
