Using VSCode to program the TXT 4.0 / Programmierung des TXT 4.0 mit VSCode
rubem
Beitrag von rubem » 11 Jan 2026, 20:11
(Deutsche Übersetzung im nächsten Beitrag)
Hi everyone,
At the risk of being ultra-repetitive, I still think that fischertechnik does not provide a good workflow for developers at all. Graphic programming is interesting, but starts to become cumbersome very quickly and cannot do everything. So I'm trying my hand at Python, but ROBO Pro Coding sucks bigtime in general and especially as a code editor. Its flaws are so numerous I don't even know where to start. (It already has my vote for the Worst IDE Ever Contest.)
So I'm using VS Code and WinSCP to sync files with the TXT 4.0. It works, but debugging is impossible up to now. I don't know how to read the console output. It seems that ROBO Pro Coding has some way of intercepting the console output, but I don't have aq clue about how to do it. Does ft share such information? Another possibility would be to display the console output on the TXT4's display screen itself, but I don't know how to do that either. Heck, I don't even know how to access the display procedurally. I didn't find it in David Adam's book either.
Anyway, for those who want to try their hand at VS Code + WinSCP, here is the method I use:
  1. In the TXT 4.0: Enable Settings / Services / SSH
  2. In the TXT 4.0: Enable Settings / Remote access / SSH
  3. In WinSCP, open the project, using the data below for remote access.
  4. Your projects folder will be at: /opt/ft/workspaces/.
  5. In WinSCP, Use Ctrl+U to keep the remote folder up to date automatically. Be sure to check "Existing files only".
Remote server data
  • File proocol: SFTP
  • Host name: 192.168.15.30 (wifi) or 192.168.7.2 (USB). (Use your actual controller IP here)
  • Port number: 22
  • User: ft
  • Password: fischertechnik
Here's the URL to my current project: https://github.com/leosdad/ft-rc-vehicle
So my questions are:
  1. Does anyone know how to run a Python program and display the results on WinSCP's console?
  2. Is display.qml the only way to show something on the screen, or there is some way of intercepting bugs and displaying them on the TXT4's console?
Thanks in advance for your thoughts and responses.
Best regards,
Rubem
Zuletzt geändert von rubem am 17 Jan 2026, 22:03, insgesamt 2-mal geändert.
rubem
Re: Using VSCode and WinSCP to program the TXT 4.0 / Programmierung des TXT 4.0 mit VSCode und WinSCP
Beitrag von rubem » 11 Jan 2026, 20:12
Auch wenn ich mich hier wiederhole, bin ich immer noch der Meinung, dass fischertechnik keinen guten Workflow für Entwickler bietet. Grafische Programmierung ist zwar interessant, wird aber schnell umständlich und kann nicht alles. Deshalb versuche ich mich gerade an Python, aber ROBO Pro Coding ist generell und vor allem als Code-Editor einfach nur schlecht. Die Mängel sind so zahlreich, dass ich gar nicht weiß, wo ich anfangen soll. (Es hat meine Stimme für den Wettbewerb „Schlechteste IDE aller Zeiten“ schon jetzt.)
Ich verwende daher VS Code und WinSCP, um Dateien mit TXT 4.0 zu synchronisieren. Das funktioniert zwar, aber Debugging ist bisher unmöglich. Ich weiß nicht, wie ich die Konsolenausgabe lesen soll. ROBO Pro Coding scheint eine Möglichkeit zu bieten, die Konsolenausgabe abzufangen, aber ich habe keine Ahnung, wie das geht. Gibt es dazu Informationen von ft? Alternativ könnte man die Konsolenausgabe auch direkt auf dem Display des TXT4 anzeigen lassen, aber auch das weiß ich nicht. Ich weiß nicht einmal, wie man die Anzeige prozedural ansteuert. Auch in David Adams' Buch habe ich dazu nichts gefunden.
Für alle, die VS Code + WinSCP ausprobieren möchten, hier meine Vorgehensweise:
  1. Im TXT 4.0: Einstellungen / Dienste / SSH aktivieren
  2. Im TXT 4.0: Einstellungen / Fernzugriff / SSH aktivieren
  3. In WinSCP das Projekt mit den unten stehenden Daten für den Fernzugriff öffnen.
  4. Ihr Projektordner befindet sich hier: /opt/ft/workspaces/.
  5. In WinSCP können Sie mit Strg+U den Remote-Ordner automatisch aktualisieren. Achten Sie darauf, die Option „Nur vorhandene Dateien“ zu aktivieren.
Remote-Serverdaten
  • Dateiprotokoll: SFTP
  • Hostname: 192.168.15.30 (WLAN) oder 192.168.7.2 (USB). (Hier die IP-Adresse Ihres Controllers eintragen)
  • Portnummer: 22
  • Benutzer: ft
  • Passwort: fischertechnik
Hier ist die URL zu meinem aktuellen Projekt: https://github.com/leosdad/ft-rc-vehicle
Meine Fragen:
  1. Weiß jemand, wie man ein Python-Programm ausführt und die Ergebnisse in der WinSCP-Konsole anzeigt?
  2. Ist display.qml die einzige Möglichkeit, etwas auf dem Bildschirm anzuzeigen, oder gibt es eine Möglichkeit, Fehler abzufangen und in der TXT4-Konsole anzuzeigen?
Vielen Dank im Voraus für Ihre Antworten.
Viele Grüße,
Rubem
Beitrag von fishfriend » 11 Jan 2026, 23:43
Es kann sein, dass ich das Problem nicht richtig verstanden habe.
Ich schicke vorraus, dass ich das in Python oder auf Linux noch nie gmacht habe.
Früher gab es die Möglichkeit Ausgaben auf andere Geräte oder Dateien umzulenken.
Wenn ich das richtig in Erinnerung habe, ging das aber immer über das Betriebssystem.
Ob das nun mit sys.stdout geht weiss ich nicht genau.
Sprich ob nun Meldungen/Text statt an die Konsole, auf zum Beispiel an die VSCode IDE gehen.
So wie ich das aus deinem Post lese, scheint das "nur" in eine Richtung zu gehen.
Kann es sein, dass die Ausgaben auf einem anderen Kanal übergeben werden?
Ich meine wir hatten dazu schon mal was.
Beitrag von vleeuwen » 12 Jan 2026, 14:43
See also https://forum.ftcommunity.de/viewtopic. ... ode#p56344
However the memory size of the TXT4.0, see also the VScode requirements, is to small for the remote VScode system with Python.
Google translate
rubem
Beitrag von rubem » 12 Jan 2026, 21:43
Hello Holger + Vleeuwen,
@Vleeuwen, I've already seen your post some days ago but it seems me that you are trying to run VSCode on the TXT (please correct me if I got it wrong), which should be quite interesting but it's not what I'm trying to accomplish.
Here is a reduced screen of VSCode running in my desktop. Whenever a file is edited or added to the project, WinSCP (not shown here) uploads them to the TXT4 automatically. Then I touch the button on the TXT4 screen to start the program.
@Holger, I hope I clarified it.
-------------- Google Translate
@Vleeuwen, ich habe deinen Beitrag vor einigen Tagen schon gesehen. Mir scheint, du versuchst, VS Code auf der TXT-Datei auszuführen (korrigiere mich bitte, falls ich das falsch verstanden habe). Das wäre zwar interessant, ist aber nicht das, was ich erreichen möchte.
[Bild]
Hier ist ein verkleinerter Screenshot von VS Code, das auf meinem Desktop läuft. Immer wenn eine Datei bearbeitet oder dem Projekt hinzugefügt wird, lädt WinSCP (hier nicht abgebildet) sie automatisch auf die TXT4-Datei hoch. Anschließend tippe ich auf den Button im TXT4-Fenster, um das Programm zu starten.
@Holger, ich hoffe, ich konnte es verständlicher machen.
Regards/Grüße,
Rubem
ft-ninja
Beitrag von ft-ninja » 13 Jan 2026, 00:34
Hi Rubem,
Not sure if it helps with observing output in WinSCP, but you can observe the output from your python program right in the VSCode if you start this program on the TXT40 via the SSH. I've provided a demo.py script for you. Please follow the comments:
# This is a python demo program to show the workflow for remote python execution on TXT40 controller
# 1. Connect the TXT40 to PC via the USB interface
# 2. Open the folder with demo.py in VSCode
# 3. Open the terminal in VSCode with Ctrl+~ and use it to run the following commands:
# 4. Download the demo.py script to TXT40 via SCP
#      scp demo.py ft@192.168.7.2:~/workspaces/
# 5. Execute the demo.py on TXT40 via SSH
#      ssh ft@192.168.7.2 python3 ~/workspaces/demo.py
# 6. This works in Windows 10 as well :)
# ft-ninja 2026
print("!!!")
print("Hello from demo.py on TXT40")
print("!!!")
You can bypass the password entering procedure for SCP and SSH commands by generating a SSH key pair and copying public key to TXT40. Also you can automate those scp and ssh steps using a batch script or Makefile or VSCode Tasks.
ft-ninja
rubem
Beitrag von rubem » 13 Jan 2026, 15:10
Hi ft-ninja,
Thanks a lot for your answer, looks promising! I'll try to find some leisure time this week, otherwise I'll certainly look into it during the weekend. I'll let you know via this thread.
Thanks again,
Rubem
rubem
Re: Using VSCode to program the TXT 4.0 / Programmierung des TXT 4.0 mit VSCode
Beitrag von rubem » 17 Jan 2026, 22:43
Hi everyone,
@ft-ninja, your solution worked brilliantly! I learned some "new" things in the process, among them a little bit about scp/ssh and how to run a Python command in the TXT4. WinSCP is not needed to upload the files anymore, I wrote a tasks.json to do it and run the code (with the help of GitHub Copilot, mostly using the GPT 5.2 model). Now the result is neatly captured to the VSCode terminal :D
I've made several code improvements and refactorings. I've renamed all meaningless variables in controller.py, removed several unnecessary globals everywhere (with the help of Pylint), added docstrings, and updated the instructions, among other things. If you want to see the improvements, go to my project on GitHub.
Regards,
Rubem
