Does the old Robo Pro provide a smoother experience? / Bietet der alte Robo Pro ein reibungsloseres Erlebnis?
rubem
Beitrag von rubem » 21 Apr 2025, 22:59
Hello / Hallo,
I got new ft parts, so I'm recreating some interesting models from old kits that I don't own. Among these is the Robo TX(T) Electropneumatic. I've successfully built a replica of the color sorter robot with a few changes. The main differences are the flexible silicone hoses which are thicker than the original ones, so I had to use a countersink 32321 instead of a block 15 with hole 32064 -- no big deal. I've also used my DIY pneumatic solenoid assembly instead of the solenoids 35327 which I don't have. After a few adjustments, everything is working perfectly.
So I found myself using the old TXT and the original Robo Pro again. Everything feels faster and simpler. Saving a local file is just File / Save instead of the convoluted 4-step (or so) procedure of Robo Pro Coding. Loading and running a program in the controller is much, much faster. Online mode works instantaneously. I can easily show the color sensor values on the PC screen. Using the TXT display doesn't take an extra minute or so. The documentation is comprehensive and easy to access.
Granted, the old environment is outdated and Windows-only which of course was a a big problem for many users. Robo Pro's flowchart interface is quite idiosyncratic and has a steeper learning curve. But, flawed as it is, it does provide a smoother workflow.
I wonder what are your thoughts about it.
Best regards,
Rubem
----------------------- Google Translate
Ich habe neue ft-Teile bekommen und baue daher einige interessante Modelle aus alten Bausätzen nach, die ich nicht mehr besitze. Darunter ist auch der Robo TX(T) Elektropneumatik. Ich habe den Farbsortierroboter mit ein paar Änderungen erfolgreich nachgebaut. Die Hauptunterschiede sind die flexiblen Silikonschläuche, die dicker sind als die Originale. Daher musste ich einen Senker 32321 anstelle eines Blocks 15 mit Loch 32064 verwenden – kein Problem. Außerdem habe ich meine selbstgebaute pneumatische Magnetspulenbaugruppe anstelle der Magnetspulen 35327 verwendet, die ich nicht habe. Nach ein paar Anpassungen funktioniert alles einwandfrei.
So habe ich den alten TXT und den originalen Robo Pro wieder verwendet. Alles fühlt sich schneller und einfacher an. Das Speichern einer lokalen Datei erfolgt einfach über „Datei/Speichern“ statt über die umständliche, etwa vierstufige Prozedur von Robo Pro Coding. Das Laden und Ausführen eines Programms im Controller geht deutlich schneller. Der Online-Modus funktioniert sofort. Ich kann die Farbsensorwerte problemlos auf dem PC-Bildschirm anzeigen. Die TXT-Anzeige dauert kaum eine Minute länger. Die Dokumentation ist umfassend und leicht zugänglich.
Zugegeben, die alte Umgebung ist veraltet und nur für Windows verfügbar, was für viele Nutzer natürlich ein großes Problem darstellte. Die Flussdiagramm-Oberfläche von Robo Pro ist recht eigenwillig und erfordert eine steilere Lernkurve. So fehlerhaft sie auch sein mag, sie sorgt für einen reibungsloseren Arbeitsablauf.
Ich bin gespannt, was Sie davon halten.
Mit freundlichen Grüßen,
Rubem
