TXT 3: no ssh connection possible after reset
hvn
Beitrag von hvn » 09 Apr 2025, 11:22
I have a serious connection problem with a TXT 3 contoller running 4.6.6.
Normal situation is that I use ssh to login to the controller via Wifi using 2 ssh terminals. All worked fine, until there was an power problem. Power loss happened many times before, and the solution always was to start the controller again, wait for the ssh broken pipe message (only takes a few minutes) and login again.
Now, the broken pipe message appears after a very long time and only in 1 terminal. Not good. So I try to login and it does not connect all. After some error seeking, I find out that on the controller in Network, wlan0 and netmask are empty. Checking for my other TXT controller: not empty and I can login just fine.
So I decide to edit the IP address and find that all the correct data is still there. Nothing for me to do. But it doesn't show anymore in the wlan0 display.
I decide to re-enter all wlan0 data, but this doesn't solve the problem. Still no IP data in wlan0 display and no connection. Also not after several reboots of the controller.
Is there any way I can solve this? RoboPro only connects to the controller via Wifi. Since version 4.6.6 no more via USB.
Thanks for any help.
Re: TXT 3: no ssh connection possible after reset
Beitrag von vleeuwen » 11 Apr 2025, 00:32
What is a TXT 3?
I only know a TXT or a TXT4.0.
Did you try to reinstall the TXT firmware?
Google translate
hypnotoad
Beitrag von hypnotoad » 11 Apr 2025, 07:15
With ssh -v, you can get more infos about when it is hanging. With nmap, you can see if ssh is listening at all and with ping, you can check if the txt is responding.
I would guess that the configuration is corrupted and should be reset (but don't know how this is done).
hvn
Beitrag von hvn » 11 Apr 2025, 12:45
vleeuwen hat geschrieben:
11 Apr 2025, 00:32
What is a TXT 3?
In that case, it's a TXT.
No, I didn't think of that. No even sure 4.6.6 is still around, being the community firmware.
hypnotoad
Beitrag von hypnotoad » 11 Apr 2025, 12:48
If you usw the cimmunity fw, please try creating a new sd card. All settings are stored there and the original fw is basically irrelevant for the problem.
hvn
Beitrag von hvn » 23 Jul 2025, 20:26
hypnotoad hat geschrieben:
11 Apr 2025, 12:48
After quite a bit of time, I have made another attempt to regain connection. Which failed. Upon the suggestion, I did not create a new sd card but upgraded the cfw version. Without result. However, since I have 2 TXT's, one of which is working, I made imagess of the network settings of both.
Both lower images are from the screen after pressing the Edit button.
You can see that at left, both IP addresses are shown: it's the correctly working TXT.
At right, the IP address is shown only at the bottom. That's the TXT that fails to connect.
Is there a reason that could explain the difference between the 2 network interfaces, other than that the TXT is broken?
hypnotoad
Beitrag von hypnotoad » 24 Jul 2025, 19:05
Of course, it could be that something is broken. But I think it is way too early to give up !
You should check if your txt is really connected to the network (e.g. by running `ping 10.0.0.134` or `nmap 10.0.0.134`). It could also be that the wifi password has been entered wrongly - I don't know how this looks like.
If both txt controllers run the CFW, you could try swapping the SD cards and see if the problem also swaps.
kumarbr
Beitrag von kumarbr » 16 Jun 2026, 12:13
Swapping the SD cards is probably the fastest way to narrow it down. If the problem follows the SD card, then it's almost certainly a configuration issue; if it stays with the same TXT, I'd start suspecting the Wi-Fi hardware itself.kolkata ff result
hvn
Beitrag von hvn » 23 Jun 2026, 20:22
Update:
The SD Card swap did not move the problem.
Right now the situation for the broken TXT is that the only connection possible is by USB cable (and then often with some IP issues). If you watch my https://www.youtube.com/channel/UCZHm47 ... amY_bVmHYA, you can see some of it. Most of what I do is placed behind cheap paywall.
hypnotoad
Beitrag von hypnotoad » 23 Jun 2026, 20:33
Maybe a serial connection could help to analyze the problem further. I did that once when I had the white screen problem using a cheap usb to serial converter. I checked the wiring multiple times as I am not that familiar with the txts serial port.
cheorl
Beitrag von cheorl » 27 Jun 2026, 00:43
Moin hvn,
hvn hat geschrieben:
23 Jun 2026, 20:22
Dieser Link führt zur Startseite deines Kanals, es ist unklar, welches Video wir ansehen sollen.
Es wäre besser, einen direkten Link zum richtigen Video zu veröffentlichen!
Grüß, Cheorl
brosce
Beitrag von brosce » 30 Jun 2026, 09:07
Since the SD card swap didn’t move the problem, firmware is probably not the issue. The missing wlan0 IP points more toward a Wi-Fi hardware or driver failure, and serial boot logs should show whether the interface is failing to initialize.schermo rotto scherzo
hvn
Beitrag von hvn » 07 Aug 2026, 20:32
cheorl hat geschrieben:
27 Jun 2026, 00:43
Moin hvn,
23 Jun 2026, 20:22
This should work. It's a link to the playlist about the model: https://studio.youtube.com/playlist/PL1 ... h_fLrAY6j/
hvn
Beitrag von hvn » 07 Aug 2026, 20:34
brosce hat geschrieben:
30 Jun 2026, 09:07
I'm convinced it's the hardware. Right now I can only use the USB connection, but even that gives unforeseen issues.
cheorl
Beitrag von cheorl » 08 Aug 2026, 15:01
Moin hvn,
07 Aug 2026, 20:32
Leider funktioniert der von Ihnen veröffentlichte Link nicht.
Das Ergebnis ist im unten stehende Bild zu sehen.
Fehler hvn link.png (21.25 KiB) 603 mal betrachtet
Grüß, Cheorl
hvn
Beitrag von hvn » 12 Aug 2026, 08:38
Tested the previous link in a "wrong" way. This one works the "correct" way: https://www.youtube.com/watch?v=A2XhhRI ... Xh_fLrAY6j. But it starts with the oldest video, while you should watch the latest.
