TXT update failed
_wr_
TXT update failed
Beitrag von _wr_ » 03 Jun 2023, 23:26
I managed to start the update 4.6.6->4.7.0 on a nearly empty battery. So the power went of in the middle of the update :(
The TXT is now able to booth and seems to be working OK except for wifi. But I would still like to force a new installation of the firmware. I have already tried going back to RoboPro 4.6 on the PC, but that just tells me to go back to 4.7 without an option to down-grade the TXT itself.
Is there any way to force a new firmware installation?
Thanks!
WR
_wr_
Re: TXT update failed
Beitrag von _wr_ » 04 Jun 2023, 18:32
I found this item:
https://github.com/fischertechnik/FT-TX ... om-sd-card
Since I can actually boot with the broken 4.7 installation, can I do that without needing a serial connection?
I don't have a linux PC either, so is there an alternative to make the SD card from Windows instead?
Beitrag von vleeuwen » 04 Jun 2023, 22:03
It does work with every USB to serial converter
Like the ADA-fruit ADA-284 FTDI friend
https://www.adafruit.com/product/284
Google translate
Beitrag von fishfriend » 05 Jun 2023, 08:55
I´ve never use it, but there is a TXT repair:
https://github.com/fischertechnik/txt_repair
and there the:
1_repair_FwUpdTxt.bat
But at first, i would contact the fischertechnik service by mail.
ka_rai
Beitrag von ka_rai » 05 Jun 2023, 16:44
_wr_ hat geschrieben: ↑
03 Jun 2023, 23:26
Thanks!
WR
Hallo, ich habe genau das gleiche Problem. Haben Sie eine Lösung gefunden?
DANKE
_wr_
Beitrag von _wr_ » 05 Jun 2023, 21:18
fishfriend hat geschrieben: ↑
05 Jun 2023, 08:55
Thank you! That was looking really promising but...
When I try to get a the root pwd with 0_new_root.bat I get an error:
Wait until the root password is displayed on TXT ...
Write down the passwort ...
FATAL ERROR: Couldn't agree a key exchange algorithm (available: curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group14-sha256)
Any further ideas?
_wr_
Beitrag von _wr_ » 05 Jun 2023, 21:39
I got a bit further now, but again stuck. Procedure so far:
* connect USB
* (hear the windows USB connection sound)
* use Putty
    - connection type SSH
    - IP 192.168.7.2
    - login: ROBOPro
    - pwd: ROBOPro
* sudo /usr/sbin/new_root_password.sh 60
* wait ~30 seconds, then write down root password
* the '-' are not part of the password
* make new Putty connection, this time log in as root with the new password
in 1_repair_FwUpdTxt.bat they start /sbin/FwUpdTxt
However, that file doesn't exist on mine...
I'm not sure what to do now.
ka_rai
Beitrag von ka_rai » 09 Jun 2023, 09:57
Gibt es keine Lösung, diesen TXT komplett zu flashen?
Bjoern
Beitrag von Bjoern » 09 Jun 2023, 10:16
Schon mal bei ft angerufen?
Björn
ka_rai
Beitrag von ka_rai » 09 Jun 2023, 10:27
Nein, ich bin tatsächlich auf ihrer Website registriert, um die Informationen zu erhalten
Bjoern
Beitrag von Bjoern » 09 Jun 2023, 13:49
Ich hatte mal ein Update Problem. Direkt kontaktiert und mein Problem war recht schnell gelöst.
ft hat eigentlich einen sehr guten und vor allem sehr kulanten Support.
Björn
Beitrag von fishfriend » 09 Jun 2023, 15:28
Nur so als Hinweis, wegen der Antwort in dem anderen Thema:
Ein "TXT" und der "TXT 4.0" sind zwei verschiedene Interfaces.
Ein Reparaturversuch des Betriebssystems, wie beschrieben, kann nicht auf beiden Geräten gleich funktionieren.
Zumindest der Versuch ein "anderes" Betriebssystem aufzuspielen, dürfte so nicht funktionieren.
Soweit ich mich erinnere hat der TXT ein Backup vom Betriebssystem. Inwieweit man das wieder zurückspielen kann, keine Ahnung, da ich es selbst noch nie gebraucht habe.
ka_rai
Beitrag von ka_rai » 09 Jun 2023, 15:49
Vielen Dank für diese Präzision, meiner ist der TXT, ich wusste nicht, dass es einen TXT4.0 gibt, ich dachte, wir reden über eine Update-Version lol
ka_rai
Beitrag von ka_rai » 10 Jun 2023, 09:49
09 Jun 2023, 15:28
Ich sehe die Option weder im TXT-Menü noch in RoboPro
_wr_
Beitrag von _wr_ » 10 Jun 2023, 12:34
I got in touch with fischertechnik.
There seems to be no way to revert the update through software alone. The two solutions offered are:
* https://github.com/fischertechnik/FT-TX ... om-sd-card
but I don't have a USB-serial converter (yet) and, maybe more difficult no linux system to create the sd card image.
* send the TXT to fischertehnik for repair.
I will go for the 2nd option.
In my experience ft service has always been great, and that goes back a long while. I have a letter my dad wrote in 70-ties about some part they replaced back then also.
Thanks for the suggestions!
