TXT 4.7.0 Bootloader Putty No Connection
JensNils
Beitrag von JensNils » 12 Dez 2022, 22:08
Dear Community,
I am trying to get the community Firmware on my TXT. The TXT is updated to 4.7.0 and my computer is on Windows11. Putty is installed, but I don't get a connection via USB, Bluetooth or Wifi to activate the SD Card Bootloader. Do you have any hint for me, how I can establish the connection?
Many thanks and kind regards,
Jens
Re: TXT 4.7.0 Bootloader Putty No Connection
Beitrag von vleeuwen » 13 Dez 2022, 09:09
Have you activated the SSH option in the options menu of the TXT (settings)?
Putty is an SSH connection.
There is also the option to activate boot from SD card.
No Putty is needed to run other firmware from sd card.
A bootable SD card.
Google translate
hypnotoad
Beitrag von hypnotoad » 13 Dez 2022, 09:49
Dear Jens, you just need to put a correctly prepared SD card into the TXT. If it boots the community firmware (yellow progress bar), then the SD card is prepared correctly. Afterwards, you need to set up wifi. No need to activate ssh in the community firmware.
JensNils
Beitrag von JensNils » 13 Dez 2022, 20:54
Dear both,
thanks for the hint! I will try to create a bootable SD Card.
In the TXT menu I can't find any setting to activate SSH. There are only:
  • Role
  • Networksettings
    • Bluetooth
    • Wifi Settings
Kind regards,
Jens
Beitrag von vleeuwen » 13 Dez 2022, 21:08
Under security.
You need to scroll te setting menu.
Google translate
JensNils
Beitrag von JensNils » 15 Dez 2022, 20:58
I made it! :D
Now I learned as well how to reduce the partition size of a SD Card and format to FAT32 with "Diskpart"... :)
Thanks!
