Time Delay
Marcus
Time Delay
Beitrag von Marcus » 20 Apr 2022, 17:45
Hello. I am a beginner in RoboPRO and I want to ask how I can change the time delay in RoboPRO using a variable. For example, I have a variable with a value of 5 and I want the time delay to be 5 or change according to the value of the variable. Because time delay has no direct connection to the variable. Thank you for the advice.
Re: Time Delay
Beitrag von steffalk » 20 Apr 2022, 18:13
Hello Marcus,
Happy welcome here!
As you found, the time block cannot be controlled other than statically. You will have to do some if/else blocks to choose different delays, or have some small delay repeated N times according to your needs.
Best Regards,
thkais
Re: Time Delay
Beitrag von thkais » 21 Apr 2022, 12:43
Hello Marcus,
look at Chapter 5.4 of the RoboPro-Help.
Best regards,
