ftrobopy - problem with voltage inputs in TransferArea Mode
ft-ninja
Beitrag von ft-ninja » 12 Jan 2021, 18:17
Hi @Torsten,
I found some problem with ftropbopy 1.94 - it works only with outputs. When I tried to read Input value it returns 0. My test code is simple:
#! /usr/bin/env python3
# -*- coding: utf-8 -*-
import ftrobopy
import time
txt = ftrobopy.ftrobopy('localhost', use_TransferAreaMode=True)
inp = txt.voltage(1)
for x in range(5):
    inp_voltage = inp.voltage()
    print("inp_voltage: ", inp_voltage)
    time.sleep(1.0)
Console output:
$ python test-02.py
IO-1
StartTxtDlPrg-4 Thrd-Run
Connected to  TXT TransferAreaMode firmware version not detected
inp_voltage:  0
inp_voltage:  0
inp_voltage:  0
inp_voltage:  0
inp_voltage:  0
MenueBase::Finished: ROBOProDisplayPseudoMenue not active or was activated by ROOT
By the way, If I use “use_TransferAreaMode=False” it works fine:
$ python test-02-a.py
Connected to  TX2013 firmware version 4.6.6
inp_voltage:  4220
inp_voltage:  4227
inp_voltage:  4229
inp_voltage:  4225
inp_voltage:  4222
Is there any problems with Input voltage reading in current ftrobopy release (1.94) ?
ft-ninja
Torsten
Re: ftrobopy - problem with voltage inputs in TransferArea Mode
Beitrag von Torsten » 24 Jan 2021, 14:57
Hi ft-ninja,
apologies for my delayed answer but I was very busy in the last 2 weeks.
... and yes, you were right, there was a bug in the TA code of ftroboby 1.94.
I uploaded the fixed version (1.96) to github.
Best wishes,
Torsten
ft-ninja
Beitrag von ft-ninja » 27 Jan 2021, 18:15
Thank you. Inputs voltage reading confirmed.
ft-ninja
