Linux Kernel question TXT
hvn
Beitrag von hvn » 17 Jun 2020, 19:25
I want to check the version of the community kernel on my SD card, since the latest version is 0.9.5. However, when I give "uname -a" I get "Linux FT-txt 4.1.37 #2 PREEMPT Fri Jul 14 01:42:07 CEST 2017 armv7l GNU/Linux". And for some reason, accessing the FT-GUI shows me a blank screen on the TXT. So how can I check or figure out which ftc version of kernel I use?
Thanks,
hvn
Hasi50
Re: Linux Kernel question TXT
Beitrag von Hasi50 » 27 Jun 2020, 20:00
I do not own a TXT Controller, but anyway.
You approach ist totally correct,
uname -a
shows the kernel version (a complete OS may have extra infos).
For the GUI check the HTML source (view source) in your browser. I would expect some script/adblocker
supresses the output. What Browser did you use? Try Firefox or Chrome.
In case you need more info try
dmesg | less
this will show a lot of Infos.
Plase report your Browser / Version and the URL your are actually calling.
Hope I could help.
tintenfisch
Beitrag von tintenfisch » 27 Jun 2020, 20:17
I guess you're mixing up the kernel version and the community firmware version.
I think you are looking for
cat /etc/fw-ver.txt
Which shows the community firmware version.
Best regards,
Lars
hvn
Beitrag von hvn » 29 Jun 2020, 20:59
tintenfisch hat geschrieben:
27 Jun 2020, 20:17
cat /etc/fw-ver.txt
Best regards,
Lars
Thank you, that code looks like it.
hvn
Beitrag von hvn » 29 Jun 2020, 21:02
Hasi50 hat geschrieben:
27 Jun 2020, 20:00
uname -a
dmesg | less
Hope I could help.
Thanks for your help, but tintenfish/Lars likely gave the info I need. Will try out soon.
hvn
Beitrag von hvn » 03 Jul 2020, 07:41
hvn hat geschrieben:
29 Jun 2020, 20:59
27 Jun 2020, 20:17
cat /etc/fw-ver.txt
Best regards,
Lars
This did work and showed I had to upgrade the cfw, which solved 2 problems.
