Start RoboPro
Connection: USB cable.
Start Putty with screen -r (optional)
Start test interface.
Popup with message update firmware. Answer with Ok within 2 sec. If you wait to long the update doesn't work.
During +/- 1:40 min nothing is happening.
On the console screen (repeating):
Received send file block command
IOs/s DL=0 OL=0, Cam DL=0 OL=0, I2C tr=0 by=0
On the console screen you will see now:
Received send file close command
Received send file open command
Received run command command
total 56136
drwx------ 2 root root 80 Jun 3 23:37 .
drwxrwxrwt 7 root root 640 Jun 3 23:37 ..
-r-x------ 1 root root 57477296 Jun 3 23:37 executable
-r-x------ 1 root root 512 Jun 3 23:37 signature
+ readlink -f /tmp/tmp.kgcoab/executable
+ SCRIPTPATH=/tmp/tmp.kgcoab/executable
+ dirname /tmp/tmp.kgcoab/executable
+ SCRIPTFLDR=/tmp/tmp.kgcoab
+ [ 0 = 0 ]
+ + grep -n -m 1 ^PAYLOADTOOLSBEG:$ /tmp/tmp.kgcoab/executable
cut -d : -f 1
+ payloadtoolsbeg_match=350
+ cut -d : -f 1
+ grep -n -m 1 ^PAYLOADTOOLSEND:$ /tmp/tmp.kgcoab/executable
+ payloadtoolsend_match=495
+ payloadtools_start=351
+ payloadtools_length=144
+ tail -n +351 /tmp/tmp.kgcoab/executable
+ head -n 144
+ openssl enc -base64 -d
+ gzip -d -
+ chmod u+x /tmp/tmp.kgcoab/ShowProgressOld
+ basename /tmp/tmp.kgcoab/executable
+ [ executable = executable ]
+ umask 077
+ mktemp -d -p /tmp
+ EXECFLDR=/tmp/tmp.4AAlkL
+ mv /tmp/tmp.kgcoab/executable /tmp/tmp.4AAlkL/executable
+ mv /tmp/tmp.kgcoab/signature /tmp/tmp.4AAlkL/signature
+ mv /tmp/tmp.kgcoab/ShowProgressOld /tmp/tmp.4AAlkL/ShowProgressOld
+ touch /tmp/tmp.kgcoab/executable
+ touch /tmp/tmp.kgcoab/signature
+ SCRIPTFLDR=/tmp/tmp.4AAlkL
+ SCRIPTPATH=/tmp/tmp.4AAlkL/executable
+ screen -m -d -S update /bin/sh -c /bin/sh /tmp/tmp.4AAlkL/executable restart 2>&1 | /tmp/tmp.4AAlkL/ShowProgressOld
+ exit 0
[screen is terminating]
Do nothing and wait until the TXT will switch of after some minutes.
This first time I switch on the TXT, it shows a grey screen.
After switching off and on the TXT boot fine and shows his normal screen.
The update was done.
