Flickr picture:
https://www.flickr.com/photos/fotoopa_hs/49697374982
Thingiverse files:
https://www.thingiverse.com/thing:4240737
Parts on Web:
RobotDyn Drukknop module - Groen
https://www.tinytronics.nl/shop/nl/ardu ... dule-groen
RobotDyn Drukknop module - Rood
https://www.tinytronics.nl/shop/nl/ardu ... odule-rood
3 Pins header Female
https://www.tinytronics.nl/shop/nl/conn ... der-female
These push buttons are very robust and cheap. Connecting the 2 outer wires gives you a make contact. Works perfectly on the TXT-Controller. Especially for the children this pushbutton is very handy. The cover clicks on the housing. Small PCB can be fixed with 2 or 4 screws. The bottom side contains the standard FT slots.
Frans
