fotoopa
Beitrag
von fotoopa » 31 Dez 2019, 10:34
Fischertechnik wire supports. With many designs you have a lot of wires. To combine them together I made a series of wire supports that are 7.5mm wide. The internal diameters are: 5, 7, 9 and 11mm. I also made some adapted pins to mount the supports on all possible FT blocks.
The pins are printed on the wide side at the bottom, the .stl file has to be rotated in the print software. I use PolyMaker PolyMax filament at 210°, no support needed. Print speed is 60mm/sec.
3D printfiles on ThingIverse:
https://www.thingiverse.com/thing:4076581
Frans.
juh
Beitrag
von juh » 31 Dez 2019, 15:28
Hello Frans,
another nice design and a welcome alternative to the Reedkontakt-Halter (35969). I find that cables have a tendency to slip through the straight gap when using the Reedkontakt-Halter. So, as an idea, you could consider making the gap diagonal to prevent cables from slipping, as I did in
this design.
Happy new year
Jan
dt.: Mit einem diagonalen Spalt wären Kabel noch sicherer vor dem Rausrutschen gesichert.
fotoopa
Beitrag
von fotoopa » 31 Dez 2019, 15:38
Thanks Jan!
Yeah, that's a good idea. I'll adjust the opening.
Happy new year,
Frans.
Beitrag
von PHabermehl » 01 Jan 2020, 10:46
Dear Frans,
Great designs again! And obviously you didn't party too much last night...
Kind regards
fotoopa
Beitrag
von fotoopa » 01 Jan 2020, 11:03
PHabermehl hat geschrieben: ↑01 Jan 2020, 10:46
Thanks Peter!
No, there's not a lot of partying going on here. I have to live on a strict diet, heavy partying is out of the question. I always go to sleep early. I usually have new ideas in the morning. They're developed at night. But this change was given by Jan.
Frans.
