ftduino error
bluatigro
ftduino error
Beitrag von bluatigro » 02 Jan 2019, 21:10
error :
ftduino nt a class , namspace or enumaration
#include "FtduinoSimple.h"
void setup() {
  pinMode( LED_BUILTIN , OUTPUT ) ;     // LED 13
void loop() {
  ftduino::output_set( ftduino::O1 , ftduino::HI ) ;
  ftduino::output_set( ftduino::O3 , ftduino::LO ) ;
  delay( 1000 ) ;
  ftduino::output_set( ftduino::O1 , ftduino::LO ) ;
  ftduino::output_set( ftduino::O3 , ftduino::HI ) ; //in this line of code ???
  delay( 1000 ) ;
Brian
Re: ftduino error
Beitrag von Brian » 02 Jan 2019, 21:21
Hello "bluatigro",
bluatigro hat geschrieben:error :
void setup() {
void loop() {
  delay( 1000 ) ;
  delay( 1000 ) ;
try to use a simple "." (dot) instead of two "::" in your code.
Best regards
Edit: typo
ESP8266 ersetzt RoboIF bzw. TX(T) Controller,
mit Fischertechnik Aktoren und Sensoren.
Re: ftduino error
Beitrag von MasterOfGizmo » 02 Jan 2019, 21:33
For the constants like O1 the preceding name must start with uppercase. In this case it should e.g. be Ftduino instead of ftduino. The uppercase is the class name while the lowercase version would be the instance. Have a closer look at the examples. They use this extensively.
Re: ftduino error
Beitrag von MasterOfGizmo » 02 Jan 2019, 21:35
bluatigro
Re: ftduino error
Beitrag von bluatigro » 12 Jan 2019, 12:47
is it posible to control the ftduino whit freebasic or libertybasic ?
Re: ftduino error
Beitrag von MasterOfGizmo » 13 Jan 2019, 08:00
What do you mean by controlling it?
If you want to use these to write code that runs on the ftDuino then no. These generate pc programs which cannot run on anything but a pc.
If you want to use them to run code on a pc which controls an arduino via usb then yes. Both support writing pc software that makes use of the usb serial port. You could use this to send and receive commands from and to the ftDuino.
