trailsensor TX-C to TXT
Beitrag von vleeuwen » 27 Apr 2018, 13:07
Today I tried to use a trail sensor whick is woking fine on a TX-C on a TXT.
But it does not work.
Is the old trail sensor not compatibel with the TXT?
Re: trailsensor TX-C to TXT
Beitrag von PHabermehl » 27 Apr 2018, 15:17
If you refer to #128598 https://ft-datenbank.de/details.php?Art ... b62101358b, there is no reason why it should not work on TXT.
I've used it myself without any problem.
Kind regards
hamlet
Beitrag von hamlet » 27 Apr 2018, 15:51
Hi vleeuwen,
Are you sure that you've connected the sensor correctly? In opposite to the TX on the TXT the ground rail is on the inside. You wouldn't be the first one fooled by that socket swap.
Kind Regards,
Helmut
