Connect Camera cause Windows 10 Blue Screen
Dragoni
Beitrag von Dragoni » 17 Okt 2017, 08:18
Hello,
I have a problem with my Fischer Technik 524328 Robotics TXT Discovery Set, when I connect Camera into my TXT Controller, and run program Camera Man, I got Windows Blue Screen.
I tried it 3 times, but I got the same result each time. Then I tried adding new program sheet, and only switch tab in RoboPro SW to the Camera tab and Check checkbox Live Preview, but I got Black Screen and my laptop was restart.
I use RoboPro version 4.2.4 and Windows 10 64bit PRO on Lenovo T440s laptop.
Is there any solution to this problem?
Thank you very much
ski7777
Administrator
Re: Connect Camera cause Windows 10 Blue Screen
Beitrag von ski7777 » 29 Okt 2017, 21:53
You should look in the windows error logs. Maybe thee is an issue in your usb host controller driver.
Raphael
Dragoni
Beitrag von Dragoni » 31 Okt 2017, 09:31
Ok Yeaterday I connect Camera to the TXT Controller, run program and everything works fine.
I've tried 3 * before, and I've always been hit by Windows OS Blue Screen. :?: :?:
I do not know why, but everything works fine for now, maybe the blue screen will not be repeated in feature.
Thanks a lot for your help
