Robotics TXT Controller screen - only white
Mats666666
Beitrag von Mats666666 » 01 Aug 2017, 17:12
Hi all,
I need to switch on my my Robotics TXT Controller twice to get a normal Screen. Usually it is blank white after startup. Once I switch it of and on again, I`ve the normal picture on it. the controller itself actually works, I can download a program and start it from PC via USB cable.
is there anyone out there who has similar experience. I got the device last month, so it is new to me.
Thanks a lot for some information`s
Best Regrads
Mats
ski7777
Administrator
Re: Robotics TXT Controller screen - only white
Beitrag von ski7777 » 01 Aug 2017, 19:54
I am not sure, but I think I had the same situation one time. Just turning it off and on again solved it. Since then I had no experiences like that.
You should try to contact fischertechnik in the Kontakt mit fischertechnik forum.
Raphael
Mats666666
Beitrag von Mats666666 » 02 Sep 2017, 18:40
Dear all,
I contacted Fischertechnik direct, sent the TXT Controller to Fischertechnik and they solved the issue.
Thank you very much, and thanks to Fischertechnik for a great support
Mats
