can't use Store in ftcommunity-txt 0.9.3
miclamcm
Beitrag von miclamcm » 17 Apr 2017, 07:04
i have use 8G SD Card for ftcommunity-txt 0.9.3 , after setup wifi , then click the STORE icon , but nothing happen . Please help .
miclamcm
Re: can't use Store in ftcommunity-txt 0.9.3
Beitrag von miclamcm » 17 Apr 2017, 07:49
i download ftcommunity-txt 0.9.3 from here :
https://github.com/ftCommunity/ftcommunity-TXT/releases
Beitrag von PHabermehl » 17 Apr 2017, 09:27
Good morning,
What version did you download?
The snapshot three week ago had an issue with the store. This was fixed meanwhile. IF yo did not do, just use the most recent build..
Kind regards
miclamcm
Beitrag von miclamcm » 17 Apr 2017, 10:02
Hi PHabermehl , i use ftcommunity-txt 0.9.3 can't use STORE , ftcommunity-txt 0.9.2 is ok , no problem .
miclamcm
Beitrag von miclamcm » 17 Apr 2017, 10:07
Hi PHabermehl , Thank you very much , i download before is ftcommunity-txt-0.9.3-rc.snapshot-20170331.zip , now download ftcommunity-txt-0.9.3-rc.snapshot-20170413.zip again .
Beitrag von PHabermehl » 17 Apr 2017, 10:12
Did you notice that there was no official release of 0.9.3 yet?
There are several pre-releases available, though. The most recent was built last thursday and I know that the store works.
So either you did not use the most recent build or your network connection is not working.
You can finden out the version of your firmware using the menu of the About-app.
It will read something like 0.9.3-rc.snapshot-20170413, and to help you, we would need the exact version tag.
Kind regards
miclamcm
Beitrag von miclamcm » 17 Apr 2017, 10:36
Hi PHabermehl , the Store work now . Thank you . but why the APP "Calc" and "CUBE" not here ?
Beitrag von PHabermehl » 17 Apr 2017, 10:46
They were removed from the Store by their author.
You can find "Calc" here:https://github.com/harbaum/cfw-apps/tre ... r/packages
For "Cube", you might directly get in touch with it's author, MasterOfGizmo. You might send him a private message or an eMail via the board.
Kind regards,
btw, community firmware issues are usually discussed in the sub-board "TXT-Sonderprogrammierungen" -> viewforum.php?f=33
miclamcm
Beitrag von miclamcm » 17 Apr 2017, 10:48
Hi PHabermehl , thank you for your HELP !!!!!!!
Beitrag von PHabermehl » 17 Apr 2017, 10:49
This is what the community is for... Have fun :mrgreen:
miclamcm
Beitrag von miclamcm » 17 Apr 2017, 11:02
Hi PHabermehl , how to install the APP ? they are .zip file
Beitrag von PHabermehl » 17 Apr 2017, 11:05
miclamcm
Beitrag von miclamcm » 17 Apr 2017, 11:06
Hi PHabermehl , ok , thanks again .
Beitrag von PHabermehl » 17 Apr 2017, 11:07
Especially have a very close look to the one and only image in the link. It reveals the secret of "manually" installing apps ;)
