Hallo ft,
In slic3r - printersettings - extruder1 the nozzlediam = 0.5 mm
In the software installation  (printer settings)  you advice (under extruder) to fill in: ectruder1 diameter = 0.4 mm.
Why there is a difference between this two figures ?
with kind regards
Rien van Harmelen
						Dusendurchmesser
				Markus Burkhardt
Re: Dusendurchmesser
Dear Rien,
thank you very much for your request. There is no difference between these settings, the 0.4mm in the printer settings are just wrong. Please change the value to 0.5mm. This will be fixed in an update of 3D Print Control.
Best regards
Markus
Im den Druckereinstellungen stehen fälschlicherweise 0.4mm als Düsendurchmesser. Richtig ist hier der Wert 0.5mm.
Best regards
Markus
