Date problem TXT controller
hvn
Beitrag von hvn » 10 Apr 2016, 12:46
Since recently, I find that the date on my TXT controller is set back to 01-01-2000 after power on, so I think a battery has gone empty. Should I send the controller for battery replacement or can I fix this myself?
hvn
ski7777
Re: Date problem TXT controller
Beitrag von ski7777 » 10 Apr 2016, 12:56
At the back of the Controller you can find a little screw. Open it and you can open the little pocket. Inside you can find a CR2032. After replacing it only the time and date information will be gone.
Raphael
hvn
Beitrag von hvn » 10 Apr 2016, 13:17
Thank you! Always handy to have a spare battery...
hvn
Markus Burkhardt
Beitrag von Markus Burkhardt » 22 Apr 2016, 08:37
Dear hvn,
If you want to set the time and date, use the following guideline:
  • Connect to the TXT via ssh as root.
    Set local time and date with
    date -s 2016.04.22-08:36
    Write local time to the hardware clock
    hwclock -wu
Best regards
Markus
hvn
Beitrag von hvn » 22 Apr 2016, 17:22
HI Markus,
Thank you for the information.
hvn
Markus Burkhardt
Beitrag von Markus Burkhardt » 25 Apr 2016, 15:44
Hi hvn,
you are welcome!
Best regards
Markus
