ft service ?
Gesperrt
hvn
ft service ?
Beitrag von hvn » 17 Nov 2015, 11:18
Hallo ft,
I have intermittent serious problems with my TXT controller: sudden power-off and loss of loaded software from RAM. Forum member elektrolutz advises me to contact ft-service, but I bought my Discovery set in the Netherlands in april this year. How should this be handled ?
hvn
Dirk Haizmann ft
Re: ft service ?
Beitrag von Dirk Haizmann ft » 17 Nov 2015, 13:06
Hello hvn,
for me it seems that you might have a problem with your power supply. Do you use a accu.. and is this working promperly?!?
ft
hvn
Re: ft service ?
Beitrag von hvn » 17 Nov 2015, 13:59
Hello ft,
The power-off situation happened with the fully loaded battery-pack connected, not with the power supply.
hvn
Mikka
Re: ft service ?
Beitrag von Mikka » 17 Nov 2015, 15:02
Hello,
i´m not from FT but I had a similar Problem with my TXT.
I used an older accu package and the TXT suddenly shut down. The accu was fully loaded, but it seems the TXT is a little bit sensitive with the tension.
When i use a new battery pack, the problem does not occur.
Try a power supply or another battery pack.
Greetings
Mikka
hvn
Re: ft service ?
Beitrag von hvn » 17 Nov 2015, 15:27
Hi Mikka,
Thank for the advise...I do have 2 older and 2 newer battery packs. However, this doesn't change the other problem I have: programs disappearing from RAM.
So I still want to hear from ft about a solution.
hvn
Dirk Haizmann ft
Re: ft service ?
Beitrag von Dirk Haizmann ft » 17 Nov 2015, 15:48
Hello hvn,
I have to inquire once more. Which kind of "battery pack" do you use? In english battery pack normaly means a rechargeable "battery".
Is it a rechargeable accu, a 9V battery block, a old fischertechnik battery box with AA batteries.... What kind of batteries do you use?
Is it the accu from the fischertechnik Accu Set?
ft
hvn
Re: ft service ?
Beitrag von hvn » 17 Nov 2015, 16:08
Hello ft,
All 4 batterypacks (accu's) I use with my 2 mobile robots (1 with RoboInterface and 1 with TXT) are the NiMH accu's from the fischertechnik Accu Set. In the past I used to charge them with the old NiCad charger, but since I found out this one doesn't completely charge NiMH accu's I bought the new charger. I never use other accu's and use all 4 for both robots. I don't know which 2 were bought last with the TXT (I didn't put a marker on them).
hvn
Dirk Haizmann ft
Re: ft service ?
Beitrag von Dirk Haizmann ft » 17 Nov 2015, 16:30
Hello hvn,
thank you for the answer. If the energy supply isn't the problem we have to check the TXT Controller.
Please send us the controller (with a short copy of this topic) to fischertechnik GmbH, Serviceabteilung, Klaus-Fischer-Str.11, 72178 Waldachtal.
Thank you...
ft
hvn
Re: ft service ?
Beitrag von hvn » 17 Nov 2015, 17:18
Hello ft,
I will send the TXT controller. And the broken tire, as it is of no use anymore.
hvn
Dirk Haizmann ft
Re: ft service ?
Beitrag von Dirk Haizmann ft » 18 Nov 2015, 08:17
Okay... then we can check both.
ft
hvn
Re: ft service ?
Beitrag von hvn » 19 Nov 2015, 15:42
Hello ft,
The package was sent today, including 2 parts and short forums topics.
hvn
Dirk Haizmann ft
Re: ft service ?
Beitrag von Dirk Haizmann ft » 23 Nov 2015, 08:25
... we're looking forward to receive to parts.
ft
Dirk Haizmann ft
Re: ft service ?
Beitrag von Dirk Haizmann ft » 24 Nov 2015, 14:40
@hvn
The parts are here. We checked the problem. But there is no adress to send the stuff back.....
hvn
Re: ft service ?
Beitrag von hvn » 24 Nov 2015, 15:55
ft,
Oops. To what email address can I send my address ?
hvn
Dirk Haizmann ft
Re: ft service ?
Beitrag von Dirk Haizmann ft » 25 Nov 2015, 08:43
@hvn
I did expect this question from a forum fan like you.
Just send a mail to info@fischertechnik.de
ft
hvn
Re: ft service ?
Beitrag von hvn » 25 Nov 2015, 09:51
ft,
Ok, email is sent.
hvn
Dirk Haizmann ft
Re: ft service ?
Beitrag von Dirk Haizmann ft » 25 Nov 2015, 10:40
THX
ft
Gesperrt
