Robo TX Controller firmware update failure
grizeldi
Beitrag von grizeldi » 21 Feb 2015, 20:34
Hello everyone!
I have recently updated my RoboPro to version 4.1.3. Looks good. But after playing around with new features I wanted to make a new program. But here comes the problem: I connected up my TX Controller and clicked the Test Interface button. RoboPro asked me to update TX firmware (Robo Library) to version 1.30.05 (old version was 1.30.01). I clicked OK, everything seemed normal. But after 15 minutes it was still stuck at "Uploading: Boot_fs.img". I tried several times and sometimes it didn't even write that... Red light on TX didn't flash and I think nothing was even going on :( (except wasting my time).
Any help would be appreciated.
P.S. I don't speak German so please English answers only.
No, I don't speak German.
Masked
Re: Robo TX Controller firmware update failure
Beitrag von Masked » 21 Feb 2015, 20:51
Hi Grizeldi,
welcome to our forum!
It seems that something went wrong in the update-process and the firmware is broken now.
Hartmut Knecht wrote here: http://forum.ftcommunity.de/viewtopic.php?f=21&t=2803 that there will be a program to fix the broken firmware. But ist does not exist yet.
I'm sorry, but I think you'll have to write an email to fischertechnik (info@fischertechnik.de). They will for shure exchange your TXT.
Regards,
Martin
grizeldi
Beitrag von grizeldi » 21 Feb 2015, 20:55
Hi Martin.
I'm sad to hear that... But you wrote this:
Masked hat geschrieben:They will for shure exchange your TXT.
I have a TX not TXT. Does that change anything?
Regards
grizeldi
Masked
Beitrag von Masked » 21 Feb 2015, 21:05
Hi grizeldi,
aaaah, I misread that.
Thats a really important point^^
You can download the TX-Repair-Kit here: http://www.fischertechnik.de/home/downl ... uting.aspx ("ROBO TX Controller Firmware Reparatur Paket")
An instruction is included.
Regards,
Martin
grizeldi
Beitrag von grizeldi » 21 Feb 2015, 21:46
Hi Martin!
I have reinstalled RoboPro. No effect. Now I'm trying to set up that firmware reset tool, but I don't know how to install drivers from a specific location in Windows 7 (since it automatically searches Windows Update). If I leave it to install from Windows Update, it installs some driver called Lego Mindstorms Firmware Update or something like that. I'm pretty sure that's not what I need (or maybe?). With that driver installed, if I run repair.bat, I get some errors, so driver is wrong.
EDIT: This is what I get when I run repair.bat:
ERROR: Access is denied.
Loading system file ...
-I- Waiting ...
Updating flash from flash image ...
ERROR: cannot find COM port with the name "fischertechnik USB ROBO Interface 200
8" or with the name "fischertechnik USB ROBO TX Controller".
Press any key to continue . . .
An clues how to fix that?
Regards
grizeldi
Beitrag von vleeuwen » 22 Feb 2015, 14:33
From what Windows 7 you are trying to update the TX-C?
x86(32 bits) or x64 (64 bits)?
Did you uninstalled the drivers too?
See "Program and Futures" Fischertechnik ROBOPro xx bits USB drivers 4.0 and 3.2.
xxx\program files\ROBOPro\USB Driver Install
you will find the drivers for the TX-C.
The TX-C firmware you you will find in:
xxx\Program Files\ROBOPro\ROBO Interface Firmware\TXController_01_30
For manual replacing the firmaware on a TX-C with a Windows X64 sustem you will need
"3 - PC Robo TX Test für MS-Windows 7,8 und 8.1, 32 und 64 bit"
Be sure that all files are unblock after downloading.
grizeldi
Beitrag von grizeldi » 22 Feb 2015, 14:45
So if I understand it correct firmware repair package doesn't wok on 64 bit windows (which my PC is) and I have to use TX test software. Also yes, my driver is still installed (I deinstalled it and then installed it back).
Do I understand it correctly?
Regards
grizeldi
Beitrag von vleeuwen » 22 Feb 2015, 22:15
I don't know if the repair kit is also working on x64.
The repair kit fix the lower level issues.
With Robo TX Test you would probably be able to (re) install the firmware files.
If the TX-C drivers are fine, you don't need to reinstall them.
grizeldi
Beitrag von grizeldi » 21 Mär 2015, 19:36
Hello again!
After fixing my firmware with the Firmware repair kit, my TX worked on older version of RoboPro. But the problem is that after update fo RoboPro I still get this:
It's stuck like this 4ever.
Help anyone?
grizeldi
Beitrag von grizeldi » 21 Mär 2015, 19:54
Nevermind, I fixed the problem by uploading new firmware with TX Tests program.
Thanks for all help.
wattsie
Beitrag von wattsie » 29 Mär 2015, 03:35
I am having a similar problem as grizeldi.
When I try and update the firmware (to 1.30) on a Robo Pro TX from the Robo Pro test button in the software it hangs just as in grizeldi's screen shot.
I am on windows 8 x64.
If I try and launch the Robo TX Test application I get a message that 'The library [FtMscLibEx] could not be initialised'
I am using the latest version of the Robo Pro software.
Any help would be appreciated. I am an English speaker - my German is no good!
wattsie
Beitrag von wattsie » 29 Mär 2015, 03:41
Never mind thanks. Problem fixed (although randomnly!)
grizeldi
Beitrag von grizeldi » 29 Mär 2015, 18:05
wattsie hat geschrieben:Never mind thanks. Problem fixed (although randomnly!)
How did you fix it?
Because it Works good on my PC with Windows 7, but when I try it on Windows 8 I get the same error message...
FrankHaymes
Beitrag von FrankHaymes » 22 Jun 2016, 04:31
I tried to upgrade my Robo TX Controller.
It does not work now.
I am using window 10.
What do I need to do?
Frank G. Haymes
