Need ReleaseNotes.txt from ROBO Pro Update 4.1.3
ft-ninja
Beitrag von ft-ninja » 11 Feb 2015, 13:21
Hello folks,
could you please paste here content of the ReleaseNotes.txt file form ROBO Pro Update 4.1.3.
Thanks.
ft-ninja
ft-ninja
Re: Need ReleaseNotes.txt from ROBO Pro Update 4.1.3
Beitrag von ft-ninja » 15 Feb 2015, 22:56
Used 7-Zip to extract Relasenotes.txt without installation:
Changes in version 4.1.2 vs. 4.1.1
- TXT: Reworked motor command finished flag transmission for better reliability with unreliable connections
- ROBOPro: Support for IR remote control
Note: the two switches can be used as separate inputs in level 4 and higher.
The switches are a bit non intuitive because the state is only transmitted when another button is pressed.
ft-ninja
