Gerade bei Knobloch gefunden:
https://knobloch-gmbh.de/de/quadratur-e ... riebemotor
Scheint bisher keine gesehen zu haben, deswegen poste ich das jetzt. Man könnte auch mal einen Thread machen mit den Neuigkeiten und Sonderaktionen bei Knobloch.
Knobloch: Quadratur-Encoder-Motor (9V)
E Hoffer
E Hoffer
Re: Knobloch: Quadratur-Encoder-Motor (9V)
Having the encoder make no sense if there is no decoder function on the TX-C and TXT available.
The suggestion for this software was already raised more than 3 years ago.
1 motor cost 2 Counter inputs.
- H.A.R.R.Y.
Hello,
this special precious is not intended for basic use with TX or TXT but for the more professional usage with dedicated equipment. Just a pitty is that there was enough interest but nearly no one got the message that it is available from Knobloch several month ago. I found it by chance in the old shop.
Regards
Regards
I disagree with HARRY.
With a nice firmware based decoder running on the TX-C or TXT, this motor could be very useful in the fischertechnik models.
This has less to do with "professional usage with dedicated equipment".
The fischertechnik TX-C and TXT are powerful enough to deal with this type of basic encoders.
vleeuwen, I don't understand what you point it. If there is no way to get it running on the TX[T] then these controllers just suck. I don't know if it is possible or not because I have neither. The Motor is in the Shop for nearly a year and if there is still no support, chances are very low that it will ever happen.
Thanks to Arduino &co getting "more professional" equipment running is pretty simple nowadays..
E Hoffer
E Hoffer
- schnaggels
I would expect there will be support for the TXT controller later next year...
