Now the TX display stopped working
1 used the reparatur TX software
2 TX is working!
Any tips! Danke Sehr...
this seems to be a known problem with the TX display. I observed the same effect (display turns off after some time) with my plotter and the DCF77 clock (no I²C device attached). The TX continues working, but the display remains "dark". After switching the TX off and on again, the display is back. I couldn't reproduce the occurence of the error conformably - sometimes it takes minutes, sometimes hours, even with the same TX, until the display switches off (and from time to time the display doesn't switch off at all...).rbudding hat geschrieben:Used the i2c GPS, worked! Now the TX display stopped working![]()
