Problem with TX controller - need help
Peterson Lewis
Beitrag von Peterson Lewis » 24 Jul 2014, 03:09
I have a problem with the ROBO TX controller.
After turning on the power, the screen on the TX controller always stays at the welcome interface and doesn't change.
Is there any simple method to solve this problem?
Re: Problem with TX controller - need help
Beitrag von vleeuwen » 24 Jul 2014, 21:04
Are you able to build an USB based connection with RoboPro?
thkais
Beitrag von thkais » 24 Jul 2014, 21:58
this behaviour looks like an abort during a firmware-update. If so, it is possible to repair the damaged software with a "repair kit", you may download it here: http://www.fischertechnik.de/ResourceIm ... ?raid=4547
Peterson Lewis
Beitrag von Peterson Lewis » 25 Jul 2014, 04:58
thkais hat geschrieben:Hi,
Thanks a lot! I believe it's the software that get with this problem. And I will try it later.
schnaggels
Beitrag von schnaggels » 25 Jul 2014, 16:39
BTW, your ft solar model in the avatar looks very intersting ;)
Are there more pictures available please?
Thanks,
Peterson Lewis
Beitrag von Peterson Lewis » 29 Jul 2014, 04:07
schnaggels hat geschrieben:BTW, your ft solar model in the avatar looks very intersting ;)
Thanks,
I'm very happy you like it, but there is no link on the Internet by now.
And now, I'm making my ft website. If it has been done, I'll tell you soon.
Peterson Lewis
Beitrag von Peterson Lewis » 31 Jul 2014, 09:21
It still can not work. Till step 2, it goes well as in the instruction that you give. But in step 3, after I use the "repair.bat" file, the TX controller's screen still stays at the welcome interface. And at the same time, the error message appears on my computer's screen.
Peterson Lewis
Beitrag von Peterson Lewis » 31 Jul 2014, 09:25
vleeuwen hat geschrieben:Are you able to build an USB based connection with RoboPro?
When I use the test button in the robopro, the message appears. It says "Error by open COM device".
