RoboTXTest 2014, FtMscLibEx
Gesperrt
Beitrag von vleeuwen » 12 Jun 2014, 00:02
PC Robo TX Test for MS-Windows 7,8 und 8.1, 32 und 64 bit
and FtMscLibEx for Windows 7 and 8(.1) both x64 and x86has been compiled with MS-Visual Studio 2012 update 4 and based on .NET framework 4.
In some case the loading of the FtMscLibEx is not working. There could be 2 reason:
1) The C++ redistributable 2012 is missing
2) (On MS-Windows 7 sp1) .Net framework 4 is missing
System requirements
A) Operating system
Windows sp1 7 x64 or x86 or Windows 8(.1) x64 or x86
Windows Vista is not been tested but it can probably work.
B)C++ redistributable
On a x64 you need to install both the x64 and x86 C++ redistributable. [VSU_4\vcredist_x64.exe and VSU_4\vcredist_x86.exe]
On a x86 you need to install the x86 C++ redistributable. [VSU_4\vcredist_x86.exe]
Visual C++ Redistributable for Visual Studio 2012 Update 4 can be found here.
Click on download an choose the file which are needed.
General information page
C).Net framework
.Net framework 4 installed ( .Net framework 4.5 is a replacement for .Net framework 4)
.Net framework 4 is part of the Windows 8(.1) installation.
Web installer .Net framework 4 for both x86 and x64, only needed on WIndows 7
Web installer .Net framework 4.5.2 for both x86 and x64 needed on WIndows 7 or 8(.1)
See: http://support.microsoft.com/kb/2468871
This information will also be added to the download package self in the near futur.
Dirk Haizmann ft
Re: RoboTXTest 2014, FtMscLibEx
Beitrag von Dirk Haizmann ft » 13 Jun 2014, 10:06
Thanks for this.
ft
Dirk Haizmann ft
Beitrag von Dirk Haizmann ft » 13 Jun 2014, 10:07
Thanks for this.
ft
Gesperrt
