RoboPro Help
Gesperrt
Ad2
RoboPro Help
Beitrag von Ad2 » 25 Apr 2012, 14:37
Dear ft,
The Help function in my RoboPro installation does not work. A window opens but closes immediately, the same happens when I try to open the *.chm file directly. I've already reinstalled RoboPro and I'm using the latest update. My OS is Vista32 with IE9, with all updates and service packs. I know that *.chm files can be 'blocked', but the ones from ft are not. Directly opening the file in IE or firefox has the same result, the window that briefly opens seems to be the table of contents.
Thanks for any suggestions
Re: RoboPro Help
Beitrag von vleeuwen » 25 Apr 2012, 17:28
Windows 7, 32 .
No problem.
Suggestion
Sometimes files, coming from the outside are initialy blocked.
If this is the case:
Select the help file in the file browser and go to the properties.
Under the tab "general" you will find, after attributies, a field "security" and an "unblock" option.
This is standard Windows practise.
Zuletzt geändert von vleeuwen am 06 Mai 2012, 21:27, insgesamt 2-mal geändert.
Dirk Haizmann ft
Re: RoboPro Help
Beitrag von Dirk Haizmann ft » 04 Mai 2012, 08:36
this a problem we haven't had before.
Does anybody else have the same problem like vleeuwen ?
Please contact us !
ft
Gesperrt
