Nice that you mentioning Google SketchUp.
Google SketchUp models with a special free (plug AR 1.0) are easily to use in MS-RDS
See http://artificialrobotics.com/about.php
For the moment their is only support for MS-RDS 2008 R3.
Split: ft-Designer
Re: ft Designer
Zuletzt geändert von vleeuwen am 12 Apr 2012, 14:42, insgesamt 1-mal geändert.
Re: ft Designer
Nice that you mentioning RDS.
RDS is easily to use with the MS Windows trash can.
E Hoffer
E Hoffer
Re: ft Designer
@Defiant,
I am looking forwards to the basis of you opinion.
Only almost anonymous big words are not so helpful in discussions.
Don't forget that fischertechnik is a partner in the MS-RDS project.
Solid grounds of your advice can help them to makes there work better.
Re: ft Designer
Basis? -aka instruction? here is how to reproduce:
1. Open the folder you installed RDS to
2. Mark all files and press the "del"-key on keyboard
3. Confirm with yes.
4. Open the trash, it should list your RDS files now. If so we have proven that RDS is compatible with the Trash.
However I'm not sure if I correctly understood your last post.
E Hoffer
E Hoffer
Split: ft-Designer
Ich habe den Thread http://forum.ftcommunity.de/viewtopic.php?f=8&t=1277mal geteilt ,das gehört nun wirklich nicht zusammen.
I've splitted the thread http://forum.ftcommunity.de/viewtopic.php?f=8&t=1277 , that was really off-topic.
Martin
Martin
