Problem bei der Programierung des TX Controllers in C
Martin S
Beitrag von Martin S » 27 Mär 2012, 15:09
Ich hab folgende Frage
Wie kann ich einzelne Pixel des Displays anmachen?
Ich weiß von den Beispielen das man eine Art Message Box mit
p_ta->hook_table.DisplayMsg(p_ta, "Nachricht");
aufrufen kann. Ich würde mich aber mal an einem Tetris versuchen wollen wo ich einzelne Pixel setzten muss versuchen.
Mfg Martin S
Re: Problem bei der Programierung des TX Controllers in C
Beitrag von vleeuwen » 27 Mär 2012, 16:22
See (teil 2 version 1.4)
8.8 Struktur TA_DISPLAY
I guess that you must use the DISPLAY_FRAME struct to display bitmap images.
But this part is not realy documented.
You need to figure out how it works yourself.
Martin S
Beitrag von Martin S » 27 Mär 2012, 17:07
Have you an idea how this could work?
I tested many but nothing did work.
I would be very lucky if you have a solution.
Mfg Martin S
Beitrag von vleeuwen » 27 Mär 2012, 18:33
I did not had time to test it but my hypothesis is:
DISPLAY_MSG.id=0; (do not make use of DISPLAY_MSG struct)
DISPLAY_FRAME.FRAME points to a 128*8 bytes array representing the bitmap (b/w).
DISPLAY_FRAME.is_pgm_master_of display= true
DISPLAY_FRAME.id=1 //probabely the change of this value will activate the transfer of the bitmap.
The bitmap will be transfer to the TX-C in parts (pages of 64 bytes).
The Transfer Area do not have more space available for the display information.
So there are 16 TA cycles needed to tranfsfer 1 bitmap.
I am expecting that the DISPLAY_MSG will be use by the transfer software to transfer the pages.
Let me know if this is working.
Martin S
Beitrag von Martin S » 29 Mär 2012, 22:27
Hello
I´ve got this code now witch display me something like a big chaos.
        unsigned char temp[64];
	p_ta->display.display_msg.id=0;
	p_ta->display.display_frame.is_pgm_master_of_display = 1;
	p_ta->display.display_frame.id=1;
	int z;
	for (z= 1;z <= 16;z++){
	p_ta->display.display_frame.frame=temp;
I expected to get a blank screen.
Mfg Martin
Zuletzt geändert von Martin S am 29 Mär 2012, 22:30, insgesamt 1-mal geändert.
Martin S
Mein Browser hat die letzt Nachricht doppelt gesendet.
Könnte das hier bitte jemand lösche.
Beitrag von vleeuwen » 29 Mär 2012, 23:17
Based on the documentation I am expecting that the
p_ta->display.display_frame.frame needs to contain a pointer to a 128*8 bytes array.
This array needs to contain representing the bitmap (b/w).
The split up of this array into parts will be done by the FtMscLib self.
Try to monitor the value of the id and the pointer.
Sorry that I don't have time to test this myself.
unsigned char * bitmapPointer;
unsigned char bitmap[128*8];
tempPointer=bitmap;
Don't forget to created the array itself.
Zuletzt geändert von vleeuwen am 30 Mär 2012, 17:53, insgesamt 1-mal geändert.
Ad2
Beitrag von Ad2 » 30 Mär 2012, 17:01
@Martin S
Your code:
   int z;
Has some C errors. There is no assignment of entire arrays in C. var=temp; assigns the address of the array 'temp' to var, not the values in temp. Array indices in C start at 0, although you don't use 'z' as an index (why not?) it should normally look like "for (z=0;z<64;z++)". Furthermore your array temp likely contains random data.
On the positive side: At least something is happening.
Ad
Martin S
Beitrag von Martin S » 01 Apr 2012, 18:54
I feel realy helpless now. :(
Here is my current code :
int i;
int PrgTic
    TA * p_ta_array,    // pointer to the array of transfer areas
    int ta_count        // number of transfer areas in array (equal to TA_COUNT)
    int rc = 0x7FFF;
    TA * p_ta = &p_ta_array[TA_IDX];
	unsigned char * bitmap[64];
	int z;
	if(i==0){
	if(i<16){
		p_ta->display.display_frame.id=+1;
		p_ta->display.display_frame.frame=bitmap;
	i++;
	return rc;
I don´t know whats gone wrong.
I get a Chaos on the display and some pixels are blinking.
I would be very happy if i get some help. :D
Mfg Martin525
Beitrag von vleeuwen » 01 Apr 2012, 19:34
A couple of thinks in your code are not clear to me
1)
A bitmap is 128*64 bits (or 128*8 bytes).
-> Where is this bitmap defined in your code?
->What is the value of each pixel (bit, black or white)?
2)
What is the role of i?
Did you create a 128*8 byte array (allogate memory space for this array; with each byte =0)?
The TA description only ask for a pointer to an existing bitmap array (of 128*64 bits (128*8 bytes) and not 64*8 bytes).
And to increase the Id.
After that wait and see what will happen.
Ad2
Beitrag von Ad2 » 02 Apr 2012, 10:43
I haven't tried myself but I have some comments on your code
int i; //make this int i = 0;  variables should be initialised
int PrgTic
    int rc = 0x7FFF;
    TA * p_ta = &p_ta_array[TA_IDX]; //I guess TA_IDX is the index for your current TX controller
   unsigned char * bitmap[64]; //this defines an automatic array of 64 pointers to bytes and is NOT initialised, this is probably not you intend
   int z; //unused
   if(i==0){ //first time
   if(i<16){ //16 times
      p_ta->display.display_frame.id=+1;// not clear: =+ used to be an operator (deprecated), write: var = 1; or var += 1; depending on what you mean
      p_ta->display.display_frame.frame=bitmap; //this assigns the address of your array of pointers to the frame variable, the array is on the stack so both its address and
        //contents may vary from invocation to invocation. recommendation: use a static array, eg.: static unsigned char bitmap[128];
        //and initialise it in eg. i==0. Or even easier, declare it globally, initialise it in the init function and update it in the tick function.
   i++;
   return rc;
