RoboPro 4.4.3
Re: RoboPro 4.4.3
Beitragvon chehr » 23 Aug 2018, 14:58
Hello eliseur
wrt https://forum.ftcommunity.de/viewtopic.php?f=21&t=4914, I had a similar problem which is solved, now by re-installation of the USB driver as described in https://forum.ftcommunity.de/viewtopic.php?f=8&t=4899#p35604. I had no access to the TXT via USB, only via WLAN or BT
So I would propose to try again updating the TXT controller after re-installation of the USB Driver.
It was not feasible to update the TXT via WLAN, the error code was as shown in https://forum.ftcommunity.de/viewtopic.php?f=8&t=4899#p35599.
Regards
Christian
chehr
Re: RoboPro 4.4.3
Beitragvon eliseur » 24 Aug 2018, 09:16
Danke Christian
My problem is not that the update did not work: it has worked. The problem is that after the update, the connection with the controller doesn't work , via usb, bluetooth or wlan:
The Test function of Robopro indicates "state of port: stopped".
The camera images do no more show in Robopro, and the sound functions of the controller do not work.
The origin of the problem is not the driver, I guess, because then connection should work through Wlan.
I suspect that something went wrong with the update of the firmware of the controller, or that the controller itself is noit fir for the 4.4.3 firmware.
Kind regards,
eliseur
Re: RoboPro 4.4.3
Beitragvon calcman » 09 Feb 2019, 14:57
hamlet hat geschrieben:Hallo Community,
Ein klitzekleines "sudo" vor dem "new_root_password.sh"-Aufruf hilft ungemein:[code] _____ _____ _ _
| ___|_ _| | |___ _| |_
| |_ | |_____| __\ \/ / __|
| _| | |_____| |_ > <| |_
|_| |_| \__/_/\_\\__|
Welcome to FT-txt
$ sudo /usr/sbin/new_root_password.sh 99
Hmmm, klingt alles gut und vernüftig, bei mir will der TXT aber jetzt gerne ein Passwort haben, ich vermute mal das root-pw . Und da beisst sich die Katze in den Schwanz. Hat irgendjemand eine gute Idee?
Ach ja und noch was: Beim Update (4.2.4 -> 4.4.4.) hat der TXT seinen Namen geändert. Von TXT-3173 nach TXT-0245. Ist das ein Problem, hat das noch jemand erlebt?
calcman
Re: RoboPro 4.4.3
Beitragvon vleeuwen » 09 Feb 2019, 15:39
xxxxxxxxxx
Vorherige
Zurück zu Robo Pro / Computing / Software
Wer ist online?
Mitglieder in diesem Forum: 0 Mitglieder und 5 Gäste
