ROBO Pro + Arduino ?
ft-ninja
Beitrag von ft-ninja » 23 Dez 2012, 19:18
Hello Folks!
Is it possible to control Arduino UNO board from the ROBO Pro programm in Online mode?
Any ideas?
UPD 26.12.2012
Now I have logged traffic data between RP and TX-C - link.
UPD 28.12.2012
Now we know all command codes that used in simple session. Also we have identified structures for INPUT and OUTPUT update packets. First sketch for FishX1 parser in pseudo-code is ready.
link.
UPD 31.12.2012
At this moment the first release of fx1parser is working. Youtube demo-clip recorded.
link
UPD 04.01.2013
Finally we have fx1-arduino-parser ready for testing for everyone. Enjoy!
link
UPD 20.05.2015
Project fx1-arduino-parser moved to GitHub due to Google Code closure.
link
UPD 03.09.2015
fx1-arduino-parser v0.2 released on GitHub.
link
UPD 12.08.2016
fx1-arduino-parser v0.3 released on GitHub.
link
UPD 19.02.2021
Tested with ROBO Pro 4.6.6. Download here https://github.com/mr-kubikus/fx1-arduino-parser
Zuletzt geändert von ft-ninja am 09 Aug 2021, 17:49, insgesamt 16-mal geändert.
ft-ninja
Re: ROBO Pro + Arduino
Beitrag von vleeuwen » 23 Dez 2012, 19:33
Yes:
*) in case you implement the functionality as describt in the FtMscLib library and the FtMscLib can connected itself to the Anduino.
*) or you to implement the RS485 bus protocol in away that your Anduino will behaive itself as an TX-C slave device.
*) or use the Andruine as a I2C slave. ( In the online mode the I2C communication is rather slow.)
Zuletzt geändert von vleeuwen am 23 Dez 2012, 19:40, insgesamt 2-mal geändert.
ft-ninja
Beitrag von ft-ninja » 23 Dez 2012, 19:39
1) Requires detailed dscription for protocol between ROBO Pro and TX-C. Do you know any related information sources?
2) For this soluition I need TX-C between ROBO Pro and Arduino. Its not good because my main idea is to control Arduino directly from RP.
3) Same situation as point 2.
ft-ninja
Beitrag von vleeuwen » 23 Dez 2012, 21:32
About 1)
The api has been describt in the documentation.
But you will need to hack the USB or BT communication, which has not been dodcumented
ft-ninja
Beitrag von ft-ninja » 23 Dez 2012, 23:16
Hello Rei Vilo,
Thank you for recomendation. But my objective is to control Arduino board directly from RP.
As I found - it's posible to select any com port that is avaible in the OS in the ROBO Pro's USB-COM menu. Arduino, when it connected to PC, also appears as virtual COM port. So we can cheat RP and gethim to send data to Arduino directly. We only need to write parser for FishX1 protocol for Arduino side.
May be you could help me to find any info about FishX1 protocol?
ft-ninja
ft-ninja
Beitrag von ft-ninja » 24 Dez 2012, 10:00
Hello Rei,
Thanks for links provided.
using the RoboPro environment to develop for an Arduino board is extremely difficult, if not impossible
I do not think so and I will try to reverse engineer communications protocol between RP and TX-C in ONLINE mode. The official data package "PC Programming ROBO TX Controller Version 1.5 PC_Programming_RoboTXC" will helps in this task. In the contents of that package I've found PDF file PC_Programming_RoboTXC_en_V1-5.pdf with section describing a parts of FishX1 protocol - 13.1 Fish.X1 interface protocol.
Following header files from data package PC_Programming_RoboTXC also will help us:
common.h
ftErrCode.h
ROBO_TX_FW.h
ftMscLib.h
Ahead we have a long holidays and lot of time to experiment with RP and Arduino.
ft-ninja
ft-ninja
Beitrag von ft-ninja » 24 Dez 2012, 10:53
I looked at the documentation and It seems that PC_Programming_RoboTXC doc doesn't contain all info about FishX1. I can't find values for Fish.X1 command code that is located at the PACKET[16] offset.
Description for this field from documentation:
Fish.X1 command code (tele-code), 4 bytes (L,H)
Defines a unique request or reply code. The command code thus describes the
supplied data structure in the payload.
Now I'm searching for a tool or method to grab all traffic between RP and TX-C in ONLINE mode. After I will have the traffic log then I will be able to analyze it and find respective values for Fish.X1 command code (tele-code) field in the data packet.
Zuletzt geändert von ft-ninja am 24 Dez 2012, 15:32, insgesamt 1-mal geändert.
ft-ninja
ft-ninja
Beitrag von ft-ninja » 24 Dez 2012, 14:44
Illustration for my previous post:
Here you can see the point where I want to grab and log the traffic between RP and TX-C. May be you know any free-ware tools that allows to connect to existing com-port and sniff traffic?
ft-ninja
ft-ninja
Re: ROBO Pro + Arduino ?
Beitrag von ft-ninja » 24 Dez 2012, 20:40
Good news!
I've found freeware tool to capture binary data from COM-port - RealTerm:
Realterm is a terminal program specially designed for capturing, controlling and debugging binary and other difficult data streams
It allows me to connect to the TX-C and send commands in the shell mode. It also has nice feature to save all data from terminal screen to text file. But I can't connect to the same COM-port when RP works in ONLINE mode. When I tryed to do that following message box was appeared:
Damn!
I continue to look for a way to grab the data from active serial connection between RP and TX-C.
Zuletzt geändert von ft-ninja am 10 Aug 2021, 11:14, insgesamt 1-mal geändert.
ft-ninja
thkais
Beitrag von thkais » 25 Dez 2012, 08:18
Hi ft-ninja,
have a look at "VSPE" - with this tool you may generate a "copy" of a serial port.
The search term "serial port monitor" should also help...
ft-ninja
Beitrag von ft-ninja » 25 Dez 2012, 11:59
Hello Thomas,
Thanks for the link to VSPE. It's a goot tool to create a "copy" of serial port, but for 64bit Win 7 it costs $24.95 :(.
Good news!
I have found (thanks to Ad2) another freeware tool - com0com. Which allows me to create a virtual COM port pair and use them to connect RP to Realterm and then to TX-C. With com0com I've success with grabbing the data traffic. I've used following structure:
Now I need a time to analyze logged data. Stay tuned!
ft-ninja
ft-ninja
Beitrag von ft-ninja » 25 Dez 2012, 20:58
After playing several hours with com0com and Realterm I came to solution that allows me to log a data stream between RP and TX-C. For this purpose I created a dummy RP program that has only several blocks:
At the first step I configured the com0com to emulate 2 virtual COM-ports, connected together through virtual null-modem cable. It was COM10 and COM11 (please see the picture from previous post). The RP was connected to COM10. Then I started the Realterm and opened COM11 for listening.
In the ECHO PORT tab I configured the Echo function to forward all traffic from the RP to COM1, which is a virtual TX-C COM-port. This functiona also forwards a traffic from COM1 to COM11 in reverse direction. Then I started Capture function and pressed the Start button in RP. After the RP program was finished I got the binary log file. When converted to ascii hex format it looks like:
02 55 00 14 02 00 00 00 01 00 00 00 01 00 00 00 01 00 00 00 00 00 00 00 FF E7 03 02 55 00 14 02
00 00 00 02 00 00 00 01 00 01 00 65 00 00 00 00 00 00 00 FF 81 03 02 55 00 58 02 00 00 00 02 00
00 00 02 00 01 00 6A 00 00 00 01 00 00 00 00 00 00 00 52 4F 42 4F 20 54 58 2D 33 37 37 00 00 00
00 00 00 30 30 3A 31 33 3A 37 42 3A 35 34 3A 37 45 3A 31 39 00 00 04 02 00 20 00 00 70 30 00 00
0D 00 43 00 00 00 00 01 01 1E 01 01 01 08 01 01 01 04 F7 74 03 02 55 00 18 02 00 00 00 01 00 00
00 03 00 01 00 07 00 00 00 01 00 00 00 00 00 00 00 FF D9 03 02 55 00 30 02 00 00 00 02 00 00 00
03 00 01 00 6B 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 FF 5C 03 0D 67 65 74 5F 73 65 72 5F 6E 75 6D 0D 0D 0A 52 4F 42 4F 20 54
58 2D 33 37 37 2F 55 53 42 3E 67 65 74 5F 73 65 72 5F 6E 75 6D 0D 0A 30 30 30 32 31 33 31 30 34
38 0D 0A 52 4F 42 4F 20 54 58 2D 33 37 37 2F 55 53 42 3E 02 55 00 48 02 00 00 00 01 00 00 00 01
00 00 00 05 00 00 00 01 00 00 00 00 00 00 00 00 01 01 01 81 81 81 81 81 81 81 81 01 01 01 01 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FB
9F 03 02 55 00 18 02 00 00 00 02 00 00 00 01 00 02 00 69 00 00 00 01 00 00 00 00 00 00 00 FF 77
03 02 55 00 44 02 00 00 00 01 00 00 00 02 00 02 00 02 00 00 00 01 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 FF B2 03 02 55 00 48 02 00 00 00 02 00 00 00 02 00 02 00 66 00 00 00
01 00 00 00 00 00 00 00 00 00 00 00 59 00 6D 00 C9 0B C9 0B 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FC DB 03 02 55 00 44 02
00 00 00 01 00 00 00 03 00 02 00 02 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 FF B1 03 02 55 00 48 02 00 00 00 02 00 00 00 03 00 02 00 66 00 00 00 01 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF 48 03 02 55 00 44 02 00 00 00 01 00 00
00 04 00 02 00 02 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF B0 03
02 55 00 48 02 00 00 00 02 00 00 00 04 00 02 00 66 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 FF 47 03 02 55 00 44 02 00 00 00 01 00 00 00 05 00 02 00 02
00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF AF 03 02 55 00 48 02 00
00 00 02 00 00 00 05 00 02 00 66 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 FF 46 03 02 55 00 44 02 00 00 00 01 00 00 00 06 00 02 00 02 00 00 00 01 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF AE 03 02 55 00 48 02 00 00 00 02 00 00 00
06 00 02 00 66 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
FF 45 03
Here I cut the rest of file.
At the next step I used information from PC_Programming_RoboTXC.PDF to manually extract FishX1 packets fram raw data. As we know - every packet starts with 0x0255 signature and ends with 0x03 byte. After I finished this task I got following result:
02 55 00 14 02 00 00 00 02 00 00 00 01 00 01 00
02 55 00 58 02 00 00 00 02 00 00 00 02 00 01 00
20 54 58 2D 33 37 37 00 00 00 00 00 00 30 30 3A
04 02 00 20 00 00 70 30 00 00 0D 00 43 00 00 00
02 55 00 18 02 00 00 00 01 00 00 00 03 00 01 00
02 55 00 30 02 00 00 00 02 00 00 00 03 00 01 00
0D 67 65 74 5F
53 42 3E
02 55 00 48 02 00 00 00 01 00 00 00 01 00 00 00
81 81 81 81 81 81 81 81 01 01 01 01 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 FB 9F 03
69 00 00 00 01 00 00 00 00 00 00 00 FF 77 03
02 55 00 44 02 00 00 00 01 00 00 00 03 00 02 00
00 00 00 00 00 00 00 00 FF B1 03
02 55 00 44 02 00 00 00 01 00 00 00 04 00 02 00
Now I going to split every packet on header and payload. Payload is more interesting for us because it's poorly documented in PC_Programming_RoboTXC.PDF.
Zuletzt geändert von ft-ninja am 26 Dez 2012, 07:50, insgesamt 2-mal geändert.
ft-ninja
ft-ninja
Beitrag von ft-ninja » 26 Dez 2012, 19:21
Hello Rei,
Thank you for the link provided. Going to be more open - it’s a right way to keep your community growing.
Let’s look what I have for current moment.
I’ve analyzed captured packets and extracted command codes and payload size from each packet:
 FishX1 packets
 STX, Header, CRC and ETX was removed.
 Designations:
 Request from RP to TX-C - REQ
 Reply from TX-C to RP   - RPL
 Fish.X1 command code    - CMD
 Payload size (bytes)    - PL
REQ, CMD=0x01, PL=0
RPL, CMD=0x65, PL=0
RPL, CMD=0x6A, PL=64
52 4F 42 4F 20 54 58 2D 33 37 37 00 00 00 00 00
31 39 00 00 04 02 00 20 00 00 70 30 00 00 0D 00
REQ, CMD=0x07, PL=0
RPL, CMD=0x6B, PL=24
REQ, CMD=?
RPL, CMD=?
30 30 32 31 33 31 30 34 38 0D 0A 52 4F 42 4F 20
REQ, CMD=0x05, PL=48
RPL, CMD=0x69, PL=0
REQ, CMD=0x02, PL=44
RPL, CMD=0x66, PL=48
In captured data we have 9 different commands:
001(0x01)
101(0x65)
106(0x6A)
007(0x07)
107(0x6B)
005(0x05)
105(0x69)
002(0x02)
102(0x66)
Now we can compare payload size of captured packets with structures from ROBO_TX_FW.H and find out which structure was used in packets:
106(0x6A) TA_INFO
107(0x6B) ?
005(0x05) TA_CONFIG ?
002(0x02) TA_OUTPUT
102(0x66) TA_INPUT?
? – mean that I can’t identify structure for this command code. Packets without payload not listed.
The most interesting persons in the list above - commands with codes 002 and 102.
Request with CMD=002 used to send new data for TX-C’s outputs. Respective reply with CMD=102 returns states of all TX-C’s inputs.
I have some problems to identify structure for CMD=102 because payload size from captured data did not match TA_INPUT structure size from ROBO_TX_FW.H. To find the packet structure for CMD=102 I've manually connected inputs to 9V or GND and monitored for changes in the data packet. Right structure for CMD=102 payload is following:
#define N_CNT                   4           // Number of counters
#define N_UNI                   8           // Number of universal inputs
// Input structure, 48 bytes
typedef struct
    unsigned short uni[N_UNI];              // Current values of the universal inputs
    unsigned char  cnt_in[N_CNT];           // Current levels (0 or 1) on the counter inputs according
                                            // to their configuration (normal or inverse)
    unsigned short counter[N_CNT];          // Current values of the counter inputs
    unsigned short display_button_left;     // Number of milliseconds during which the left display button
                                            // is being kept pressed
    unsigned short display_button_right;    // Number of milliseconds during which the right display button
                                            // (distance from output structure) is reached
    char           reserved[16];
} TA_INPUT;
Now I have almost all information to write parser for the FishX1 protocol. Stay tuned! :twisted:
Zuletzt geändert von ft-ninja am 05 Sep 2015, 12:12, insgesamt 1-mal geändert.
ft-ninja
ft-ninja
Beitrag von ft-ninja » 27 Dez 2012, 20:52
Good news!
I have developed c-like pseudo-code for fx1parser library for Arduino. There we have several functions:
// Global variables
UBYTE8   x1FSMState;      // Current parser's FSM state.
UBYTE8   nPacketLength;   // Current packet lenght
UBYTE8   pRXPacketData[256];
// Reset parser internal data structures to defined state.
fx1ParserInit()
        x1FSMState = FSM_WAIT_STX;
        nPacketLength = 0;
// Receive and parse one symbol from serial port.
// Parser function realized as Finite State Machine.
fx1ParserParse(UBYTE8 symbol)
    switch (x1FSMState) {
        case FSM_WAIT_STX:
            if (symbol == 0x02) {
                *(pRXPacketData+nPacketLength) = symbol;
                nPacketLength++;
                x1FSMState = FSM_WAIT_55;
                break;
            break;
        case FSM_WAIT_55:
            if (symbol == 0x55) {
                nPacketLength++;
                x1FSMState = FSM_WAIT_LEN1;
                break;
            } else {
                break;
            break;
        case FSM_WAIT_ETX:
            if (symbol == 0x03) {
                fx1ParserProcPacket(pRXPacketData);
                break;
            } else {
                break;
            break;
        default:
            break;
// Execute callback functions according to command code CMD in received packet.
fx1ParserProcPacket(pData) {
    CMD = pData[OFFSET_CMD];
    switch (CMD) {
        case CMD_1:
            fx1ParserCMD1(pData);
            break;
        case CMD_2:
            fx1ParserCMD2(pData);
            break;
        case CMD_7:
            fx1ParserCMD7(pData);
            break;
        default:
            break;
Typical usage in Arduino environment should look like following example:
void setup()
  // Init UART
  // The ROBO Pro sends data at 38400 bps
  while(!Serial);
  Serial.begin(38400);
  // Init parser
  fx1ParserInit();
void loop()
  UBYTE8 s = 0;
  // Check and read one symbol from UART
  if (Serial.available() > 0 ) {
    s = Serial.read();
  // Parse FishX1 protocol
  fx1ParserParse(s);
Now I need a time to code all functions in Arduino environment and then test it with RP.
Don't turn the channel. I'll return very soon!
Zuletzt geändert von ft-ninja am 05 Sep 2015, 12:13, insgesamt 1-mal geändert.
ft-ninja
geab
Beitrag von geab » 29 Dez 2012, 11:20
Great work Ninja
would this also allow to read out data e.g. from a pressure sensor measured on the TX controller by voltage changes
in online mode ?
Cheers, Geab
ft-ninja
Beitrag von ft-ninja » 29 Dez 2012, 20:11
Hello folks,
Thank you for advice ;)
I'm still working on the arduino code fro my fx1parser. It's snowy weather outside the window and I enjoy spending my time on coding with cup of tea. It's so funny.
Dear Geab,
In my library fx1parser for Arduino I want to map Arduino's IO ports to TX IO ports. It means that you can connect any analog sensor to Arduino input A0 and then read sensor value in RP with the Universal input (8.7.1). Just configure it as A10V (Analog Input).
ft-ninja
ft-ninja
Beitrag von ft-ninja » 30 Dez 2012, 21:16
Good news - it works!
It's a good time to show you the result of my work. Please watch it on youtube.
From diplomatic point of view I'll wait for official permission from FT representative to publish my library source codes. Is there anyone who has contact with FT?
By the way, it was very happy to realize this project.
Zuletzt geändert von ft-ninja am 30 Dez 2012, 22:20, insgesamt 1-mal geändert.
ft-ninja
Masked
Beitrag von Masked » 30 Dez 2012, 21:22
Hi ft-ninja,
Good work!
There a two possibilities, I would prefer the first one:
- You can open a thread with the link to this thread in the "An fischertechnik"-category here in the forum.
- Or contact fischertechnik by e-mail, but I don't know who would be the correct contact person, perhaps Hartmut Knecht.
Greetings,
Martin
And let me guess, the answer of fischertechnik will probably be "No".
Defiant
Beitrag von Defiant » 31 Dez 2012, 11:11
You have to check your countries law, but usually there is no issue with uncommercial reverse engineering.
E Hoffer
Ad2
Beitrag von Ad2 » 31 Dez 2012, 11:18
But nobody prevents you from putting it on your homepage or googlecode, sourceforce, github or whatever
