Hello
Cortol-Set 500881
Sender CA-V0.05
Reciver 1.08
I have a problem with the reciver.
Basicly it is very simple, it keeps saying there is a short cut/ overload(blinks 4 times), even when there is nothing on it.
My truck was working well, suddenly it stopped and began blinking 4 times, and keeps doing that.
I did pull the power of, and on again, nothing changed.
I measured the power unid it was 6,99V, after charging that also did not solve anything.
After 1 minut it turns back to green not flashing, the servo for the stearing works, but when i move the left joystick it immediately turns back to blinking 4 times, also when there is nothing on the reciver.
The currend in use with the gearbox is 240mA, the truck was build with motor 32618 9V, the max currend when holding the motor is 560mA.
When i read the manuel that should not be the problem, if it is more than 250mA, the reciver should turn it off.
I have looked at other models, build with the power motor, and the power motor can take up to 1000mA, i hope the reciver can take that.
So my question, what can be the problem.
Regards Marchel
Control Set 500881
Re: Control Set 500881
Hello ft,
maybe this answer is of general interest. Or is this problem classified?
Best regards
Volker-James
Best regards
Volker-James
Hello Volker-James
No idee, i can send it back and they will check it.
When i know more i will place the answer.
Regards Marchel
Regards Marchel
- Dirk Haizmann ft
- fischertechnik Mitarbeiter
In the topic http://forum.ftcommunity.de/viewtopic.php?f=21&t=717 is this question allready answerd.
ft
ft
