RoboPro Send, receive function not be implemented yet on TXT
Beitragvon Harris Lai » 12 Mär 2018, 11:29
Hi fischertechnik,
I bought TXT discovery set on 2017/3 but RoboPro has an error (level 2-> send, receive), it shows "communication not be implemented on TXT controller yet", I have been asking for help since one year via info@fischertechnik.de and on the fischertechnik web site, and I got an answer was that it would be implemented on 2017/10. But now, the problem is still over there. Without any response at all although I have been requesting for help. I'd like to know does this function will be fixed or planed be fixed? or without schedule? Thanks a lot. We have many students are waiting for this answer.
Best regards,
Harris
Dateianhänge
Harris Lai
Re: RoboPro Send, receive function not be implemented yet on
Beitragvon HartmutKnecht » 26 Mär 2018, 12:07
Hi Harris,
the send/receive commands are necessary to send messages between 2 TXT Controllers. Unfortunately this function has not been implemented yet due to some technical issues. In the meantime all technical problems seem to be solved so that our programmers can start implementing this function within the next 3 months. The other wireless functions such as connection between PC and TXT via BT or WiFi are available. You can also connect the TXT to a WiFi network and use it as a client. More information about this function see https://www.fischertechnik.de/-/media/f ... -mode.ashx
Kind regards
fischertechnik
Hartmut Knecht
HartmutKnecht
Zurück zu Kontakt mit fischertechnik
Wer ist online?
