Industrial Models
Gesperrt
Rei Vilo
Industrial Models
Beitrag von Rei Vilo » 10 Aug 2016, 10:27
Hi!
I went through the very interesting industrial models aimed at the academia.
  • 536625 Vacuum Gripper Robot 9V
  • 536626 Automated High-Bay Warehouse 9V
  • 536627 Multi Processing Station with Oven 9V
  • 536628 Sorting line with detection 9V
  • 536629 Factory Simulation 9V
Two questions:
  • Are the Robotics TXT controllers connected through a Bluetooth LAN as the RoboTX controllers used to be?
  • Does fischertechnik plan to release adapted versions of those sets on the Robotics line?
Thank you and best regards,
Markus Burkhardt
Re: Industrial Models
Beitrag von Markus Burkhardt » 16 Aug 2016, 09:10
Dear Rei Vilo,
some of the controllers of the factory simulation are connected by ribbon cables. However, not all of them are connected. At this moment, we do not plan to release adapted versions as construction kits.
Best regards
Markus
Gesperrt
